Old 11-07-2011, 05:50 PM
fillpot fillpot is offline
Default 18x8 with 5.5 backspacing for the front 69 camaro
Will this work,stock subframe and control arms,probably will be running like a 245 tire.THANKS!
Old 11-07-2011, 06:16 PM
LS1NOVA LS1NOVA is offline
With stock stuff it will work but will be very close to the sway bar in the front and frame rail in the back at full steering lock. You didnt mention what wheel size but 17's and smaller may hit the tie rod.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 11-07-2011, 06:34 PM
Track Junky's Avatar
18x8 with 5.5 B.S. wiill work fine but 5" B.S. will work better.
I run a 17x9.5 with 5.5" B.S. and 275/40's but do to ride height had to cut wheel wells a bit to make room.
Gaetano Cosentino
Old 11-07-2011, 07:30 PM
Sorry about that there 18's.THANKS!
Old 11-16-2011, 01:38 AM
firebirddady69's Avatar
firebirddady69 firebirddady69 is offline
i have 18x8 with a 5'' back space, when I turned it all over i had about 3/4 clearence, should be fine
Old 11-16-2011, 09:06 AM
Sounds good.THANKS!
