Old 11-08-2011, 02:40 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default DBW Pedal Installation
Was curious if there are any special methods of installing a DBW pedal. I assume they just bolt directly to the firewall. Anyone got any pictures?
Chris
Old 11-09-2011, 05:28 PM
Ron in SoCal's Avatar
Hey Chris - I have not installed mine yet (soon), but eyeballing it I'm going to make a 'pad mount' up top for it to sit on so I can match a little closer to the brake pedal depth. I hope that makes sense?
Ron in SoCal
69 Camaro in progress
Old 11-09-2011, 11:52 PM
Tom.A's Avatar
Tom.A Tom.A is offline
Chris, The results and installs may vary. I say that because I first used a Vette DBW pedal and mounted it direct to the firewall. I had to heat it up with a torch to get it bent in the position I wanted. The heating process resulted in a non-working throttle for me . I switched to a Monte Carlo DBW pedal and it fit better with no bending. It also was about half the cost of the Vette pedal anyway. I don't have any pictures but the mounting flange on the Monte one required holes drilled higher.
Tom
Old 11-10-2011, 09:21 AM
ironworks's Avatar
We made a bracket that bolts the Pedal that comes with the GM harness's to a bracket that will bolt into an F-body. We make 2 different styles, one that is weld in deal, just flat plate with the bolt pattern for the pedal. The other will bolt right into the car. I have had a huge run on them lately and did not realize I did not have a picture of the bolt in bracket. They retail for 45 bucks but I sell them to Lat-g guys for 40 bucks.
Rodger
Old 11-10-2011, 09:35 AM
ironworks's Avatar
I was able to put this together
Old 11-11-2011, 10:53 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Default Gas pedal mount
Here you go Chris, this is from Jamess113
https://lateral-g.net/forums/show...dal#post293934
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
