Old 11-10-2011, 06:21 AM
brownz brownz is offline
Question Question on how to measure for rear end width?
Im doing a mini tub on my 79 camaro, I have my rear wheels done 18*12 with 5.5bs,I have a moser 12 bolt that I need to cut down and need to know what the correct way to measure for the rear end width,
I talked to DSE and they run the same size rear wheels and tires on their sec gen's and they told me what they run for width end flange to end flange but am I safe to use that?
If I set my rear wheel up would it be best to have them in the center of the wheel well of to the inside or outside?
Any and all info is needed as i want to make sure that I'm doing this the best and correct way.
Brandon
Old 11-10-2011, 10:40 AM
You can trust Kyle and Stacy at DSE, they are engineers...
Or you can set the wheel where you want it and measure between the inside mounting faces this will be the overall length. You will need to subtract the axle offset and brake rotor/drum thickness, that will give you the overall length flange to flange of the rear.
Jeff Allen
J2 Speed and Custom
