Old 11-11-2011, 09:09 AM
bret's Avatar
bret bret is offline
Supporting Vendor
Default T56 Magnum evaluation [long post]
First off, here is a link to a video that we did that outline some of the installation and some of the features of the T56 Magnum:
https://www.youtube.com/watch?v=1oXQG96aNL
In the process of building several cars over the last 30 years, most recently the 48 Hour Camaro, I have had the opportunity to use many different engine and transmission combinations. MOST have turned out very well. I’ve had great success with the 700R4, especially with a manual valve body and a Gear Vendors overdrive unit in our 66 Chevelle on the autocross and road course. I’ve used a 4L60 and a 4L80 automatic in a couple of cars with similar success. Velocity had a ZF 6 speed which I loved!
When we started planning the 48 Hour Camaro the criteria was simplicity and ease of installation, along with durability and performance. This led us to try a plain old Muncie M21 4 speed with a Gearvendors overdrive unit. I must say I really enjoyed that combination on the street and on the track. The ability to toggle between direct and overdrive by pushing a button on the shifter knob was almost an unfair advantage on the autocross and road course, and the 22% overdrive made highway use a breeze. The shifting precision was certainly above adequate and it went into the car with no modifications whatsoever.
Unfortunately, the Muncie just wasn’t up to the use [abuse?] that I gave it on the road course. I kept shucking the teeth off third gear. After the third unit I went to a Tex Racing T101a that I had laying around for another project. This was a great racing transmission…clutchless shifting up and down, light, efficient…but with the straight cut gears it made more noise in the car than any mechanical device I’ve ever seen. People would watch the car run and wonder what the hell was wrong with it! It’s other sin was that there was no adapter available for the Gearvendors overdrive unit, so highway driving was a high RPM chore. I ended up chipping a tooth on second gear at the Texas Goodguys event so I had yet another decision to make.
Why didn’t I simply go with a T56 Magnum in the first place, you ask? Well, there were several reasons. During the planning stages of the car I couldn’t seem to find a decent supplier for such a unit [I hadn’t met the guys from American Powertrain yet]. Also, I had a fairly poor experience with the TKO series Tremec units previously and wanted to explore other alternatives.
After I hurt the Tex unit in Texas I had to make something happen fairly quickly because I was scheduled to race at the Optima Ultimate Street Car Invitational right after SEMA. Over the summer I had come to know the guys at American Powertrain who have developed a VERY complete system for installing both the TKO and the T56 Magnum into these musclecars. We actually used their bellhousing/clutch/master cylinder/throwout bearing in the 48 Hour Camaro build to install the Muncie. Good people…great products.
Matt Graves, Grey Fredrick, and Robert Hall from American Powertrain had been teasing me all summer about my transmission problems with the Camaro and said anytime I wanted to “come in from the rain” they could set me up with a nice T56 Magnum. While I was still in Texas, I texted Matt and said: “ Tex broke. Bring me a T56.” So they did.
Matt and Grey swore and be damned that the T56 would go in that Camaro without cutting the floorpan. If it weren’t for the fact that I was using half height body bushings, and that we had moved the engine back by about an inch…they would have been exactly right. Even with all of my previous customizations we just cut the top of the trans tunnel out and made a new one. It just wasn’t that big a deal. The T56 is not really much smaller than the TKO, but the top is shaped differently so it’s actually a much better fit in any given trans tunnel. The video that we made [linked] gives you an overview of some of the features and benefits of that transmission…I won’t repeat them here. I do, however, want to offer an evaluation of this transmission from a hotrodders perspective.
I had MANY reliable people tell me about the virtues of the T56…Brian Finch, Mark Steilow, Steven Rupp, Mike Copeland…these are guys who flog their cars regularly and have no agenda for or against this transmission.
Grey Fredrick from American Powertrain had to teach me how to shift. [you’ll see this in the video] At 50 years old with well over 30 years of hotrodding experience behind me, I found it a little hard to believe that I didn’t know everything there was to know about shifting a dumb old transmission. Here’s the lesson: An open mind will make your car faster.
The T56 is to be shifted with 2 fingers, not your whole fist. If you try to rape this thing it will seem sticky and notchy. It shifted fast…VERY fast, at any RPM I tried it at…IF you treat it like a partner instead of a servant. It’s not tricky at all, it’s more of a mindset. I love the ratio spread…it’s never hard to keep the engine in an appropriate RPM range. I love the tall 6th gear as well. On the way to Pahrump from Vegas for the Optima event we were running…well, never mind how fast we were running. The engine was at about 3100 RPM in 6th gear with a 26” tall tire and a 3.50 gear. You figure it out. The point is that ANY reasonable [or unreasonable] highway speed is much less stressful with the T56 Magnum 6 speed.
In addition to the raw performance of the T56 Magnum, I have to comment on the service and installation kit from American Powertrain. While it is possible that I experienced wonderful service because of our personal and professional relationship, I have heard similar accolades from many other American Powertrain customers. It is a simple matter of you call..they deliver. In the end, that’s all any of us want, right?
The installation kit was as complete as any product I’ve seen. The bellhousing, hydraulic throwout bearing, clutch, pilot bearing, driveshaft yoke, crossmember…it was all there and very elegantly made. The crossmember was really unusual…it’s a nicely formed piece of 6061-T6 aluminum that looks kind of like a wing. Unfortunately we could not use it in our installation because of the dropped body mounts and the engine setback. Bummer.
The other item that I wanted to point out again [you’ll see this in the video] was the unique shifter system. It is adjustable not only for position on the trans, but the position of the shifter handle on the plate as well. In addition, the tension of the shifter is externally adjustable…you can actually adjust with a screwdriver the spring tension that centers the shifter between gears. I like this a LOT!
I still miss my Gearvendors overdrive, but this T56 Magnum 6 speed from American Powertrain is getting me over my grief nicely.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 11-11-2011, 10:59 AM
Ron in SoCal's Avatar
Great write up Bret. Let me know if this one lasts under your two fingers...
The vid link is not working....
Ron in SoCal
69 Camaro in progress
Old 11-11-2011, 11:57 AM
MattG's Avatar
MattG MattG is offline
Another great write up Bret! I have the same trans and love it with one gripe, the stock shifter.
My last shifter was a Pro 5.0 with a regular t56 and it was a much better shifter than the stock shifter that comes with the Magnum. I hear that Pro 5.0 is working on a shifter for the Magnum...I hope it's true. The stock magnum shifter is a little vague sometimes but certainly livable.
I just saw the video and you have APT's shifter and it sounds like it is much better than the stock unit, I'll have to check into that...looks like a much better deal than the stock one!
Once again thanks for the objective write up!
Matt
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 11-11-2011, 12:45 PM
Found it:
https://www.youtube.com/watch?v=1oXQG96aNLU
Ron in SoCal
Old 11-11-2011, 04:10 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Bret,
Thank you for posting up the information and the video. Very informative and useful!
Curtis
Old 11-11-2011, 08:35 PM
DFRESH's Avatar
DFRESH DFRESH is offline
So I missed it guys, what shifter is Bret using on his Magnum? Is that the reason the shifting is so accurate, or is it the T56 itself, regardless of shifter used? Sounds like it might be both---School me.
I now have this same trans in my car---but with the stock shifter--the hurst blackjack that came with it was a throw away--the stocker works much better but has a longer throw obviously.
Would love to know what a great shifter for this trans is that has been used by you guys at the track, auto crossing and street use since that's how I continue to use mine.
D
Old 11-14-2011, 07:55 AM
bret's Avatar
Supporting Vendor
The shifter is the White Lightning from American Powertrain http://www.americanpowertrain.com/Sh...echanisms.html
I thought it was one of the more clever features of the overall system. LOTS of adjustability, and the action is very crisp. It also has a reverse lockout. You have to have your foot on the brake to get it into reverse. It can screw up the civilians, but its a nice feature. If they are not aware that they need to have their foot on the brake pedal to get it in reverse...they don't need to be driving the car anyhow!
Bret Voelkel
President
RideTech
Old 11-14-2011, 09:43 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Nice writeup! Cant wait to get mine back (T56 mag going in now!).
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 11-14-2011, 08:02 PM
DFRESH's Avatar
Excellent, thanks Bret---that's what I was looking for. I'm going to put this one in the car---
Doug
Old 12-26-2011, 11:44 AM
seancarole seancarole is offline
I watched alot of the 48 hour build that was alsome! Thanks for the great write up on the t56 how well is holding now that you all have been beating on it? I'm in the market for new trans and mostly drag strip and most vendors I've talked to advice me away from the t56.
