Old 11-14-2011, 09:44 PM
Sieg's Avatar
Sieg Sieg is offline
Default Brake fluid disappearing
Off the PT topic but relates to ABS brake systems........
'05 Toyota Tundra pickup. Brakes have been trouble free since new. Still running stock rear drum shoes, replace front pads 6 months ago. Twice in the last two months the brake warning light has come on. Checked fluid in the reservoir the first time and it was close to minimum, visually checked the lines for leaks and refilled with 5.1 fluid.
A month later it comes on again, pull the rear drums and inspect wheel cylinders...dry, adjusted the shoes as I'd noticed the parking brake tension was questionable, check lines and junctions, no leaks.
Yesterday the light comes on again and the reservoir level is close to minimum. I go under the truck with a flashlight and check every brake/abs line, reservoir, rotor/drums for any sign of fluid both visual and with my hand. Couldn't find a trace of brake fluid on the vehicle, nor has there been any on my clean concrete driveway.
Vehicle has not had the sytem flushed so it is OEM fluid from Dec '94 build date. Filling with 5.1 which is supposedly compatible.
I'm close to stumped, it's like it is evaporating.
Anyone have a similar experience?
Old 11-14-2011, 10:00 PM
Leaking out the back of the master cylinder into the booster.
Old 11-14-2011, 10:08 PM
Sieg's Avatar
I don't exactly like what you're saying but that's my primary conclusion at this point. Is that a common occurrence?
Old 11-14-2011, 10:22 PM
I have no idear but it's easy to check. Unbolt the master and you should be able to pull it out a little and take a peak. I'd also pull the vaccum hose and take a look.
Old 11-14-2011, 10:31 PM
Sieg's Avatar
Thanks for the input, I respect your knowledge and insight.
Old 11-14-2011, 11:07 PM
elitecustombody's Avatar
I agree with Todd, it's a good possibility that's where the fluid is disappearing.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 11-15-2011, 10:44 AM
Sieg's Avatar
Thanks for the second opinion.
Upside is it "appears" it might not be too tough to access:
Old 11-15-2011, 01:47 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
It's fairly common among various Toyota models. You'll need a master cylinder and booster, as has already been suggested.
I would highly suggest using Toyota brand fluid. They recalled a bunch of newer Toyota's and Lexus' to replace a brake master cylinder seal that was not compatible with the additives in some aftermarket brake fluids.
I'm very familiar with those, if you need any help PM me. Good luck!
Erik
69 Camaro
Old 11-15-2011, 09:26 PM
SLO_Z28 SLO_Z28 is offline
That failure is more common than you would think in many different makes and models. From that picture it looks like you could unbolt it and tweak it just far enough to see behind it and see if its wet.
James F.
1974 Camaro Z28
Old 11-20-2011, 01:39 PM
Sieg's Avatar
Un-bolted and inspected.........wet push-rod
The master and booster is sold as a unit, the OEM unit only lists for $2200, negotiated $1770.
