Old 11-18-2011, 08:30 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Angry How to remove 68 camaro rear window molding
Hello guys
I have got the tool to remove the rear window molding. I have tried several times to locate the clips to pop the molding out, but I could not
So is there a way that you guys know of to easily locate the clips to remove the moldings.
Please share your inputs to help out the poor guy with his problem.
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 11-18-2011, 12:44 PM
DOOM's Avatar
DOOM DOOM is offline
You should be able to slide the clip tool between the glass and the molding until it stops. The too should have a hook on it when it stops just pry downand the molding should pop..
Mario
USCOLLISION
Old 11-18-2011, 02:16 PM
72Z/28's Avatar
I did slide the tool, but I failed to get it popped. The molding is firmly attached to the window in areas, there is no gap between it and the molding.
Thanks for the though, i will try again.
72 Camaro RS:SOLD
68 Camaro:
