Old 11-18-2011, 09:13 PM
gibby gibby is offline
Default body bushings
I need help deciding which body bushings to use. I want my car to handle but I have been told poly will stiffen the ride to much but rubber is to mushy. Just wanted to make an informed decision before I order. Thanks for any suggestions you have.
Old 11-18-2011, 10:00 PM
Ron in SoCal's Avatar
My .02....Poly or alum Gib if you plan on running your car hard. If it's just a street car and ride/comfort is important than stick w rubber.
Ron in SoCal
69 Camaro in progress
Old 11-19-2011, 12:36 AM
skatinjay27's Avatar
also not sure if you know but if you plan to run subframe connectors you'll need to run solids.
AJ
Old 11-19-2011, 09:01 PM
Thanks guys quit a coincidence I was just given given a set of solid bushings by a friend of mine today. Thank you for your help
