Old 11-21-2011, 12:46 AM
71OLDS's Avatar
71OLDS 71OLDS is offline
Default NewGen 500s (olds SSIs) on my 442
My 18" New Gen 500s are mounted. Don't have the Olds caps yet and only one coat of painted on white letters but these pics at least give an idea of the look. I know these are NOT the smaller sidewall, lowered "pro-touring" look (especially with the white letters) but I'm going for a little bit "older school" with fatter sidewalls fully exposed. Not sure I'm feeling the Nitto painted letters but I do love the Nitto tires. May switch to some Goodyear Eagle GTs in similar sizes just to get the letters to look better. Sizes are:
18x8 255/45/18
18x10 305/45/18
Joe Lincoln
1971 Olds 442 Convertible & 1970 Cutlass Supreme
Old 11-21-2011, 02:01 AM
Flash68's Avatar
Flash68 Flash68 is offline
Those look great on that car. Nice choice!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 11-21-2011, 08:56 AM
cencalc6 cencalc6 is offline
Very Nice!
Old 11-21-2011, 09:16 AM
buickfunnycar.com's Avatar
Thumbs up Dare to be different...!
That looks badass...!
www.buickfunnycar.com
Old 11-21-2011, 10:40 AM
Love the wheel on this car, perfect application for the wheel. I think once you get the custom caps EVOD is machining for you, then it will really be the finishing touch.
I'm 50/50 on the white letters myself. I kinda like it, but kinda don't...
Old 11-21-2011, 11:38 AM
71OLDS's Avatar
Thanks guys. Appreciate the positive feedback.
Jon, I feel exactly the same. Problem is I don't think this much sidewall exposed WITHOUT the RWL would look right. I think I would need to go to a smaller sidewall and then lower the car front and back so it sits right over the top of the rim. Then I would lose that Old School look I'm going for.
The Nitto letters are too far away from the rim. Obviously Nitto doesn't make a RWL tire so it really didn't matter where they put the blacked out letters. If you look at the 15" RWL tires like BF Goodrich Radial TAs or Goodyear Eagle GTs you will see the letters are closer to the rim and centered on the sidewall. Goodyear Eagle F1 GS rear tire (295/45/18) would be perfect with painted on letters in the rear and the Goodyear Eagle F1 Assymetric 2 tire (only available in the UK right now) in a 255/45/18 tire would look perfect in place of these Nittos. With about 5 coats of paint on there no one would be able to tell they weren't 18" RWL tires. The front tires would be a non issue to swap (if I could get them from the UK) but the rears would never be as good as my 305 drag radials. I've be giving up traction (and about 1/2" in diameter and a little width) for the correct RWL look.
We'll see. Maybe I could go with the fronts, shave the 305 Nittos so there are no letters, and the stencil on the Goodyear letters?? Sounds like a lot of work!
-Joe
Joe Lincoln
Old 11-21-2011, 03:50 PM
nacnac nacnac is offline
they definitely work. Like the white letters too.
Old 11-21-2011, 06:21 PM
AvatarOfAwesome AvatarOfAwesome is offline
Wow, those wheels look great! These are definitely the wheels that will go on my '79 Z28. I like the painted white letters, but I can see where you're coming from about them being too far away from the rim. Still, I think it looks like a good mix of old and new school, just like the car.
Old 11-22-2011, 10:38 AM
nvmyss nvmyss is offline
Great wheel choice for an A-body.
The white not so much, the rest A+
Adam
69 Chevelle SS 396 < --Sold
67 Camaro
06 2500 Dodge Ram Diesel
93 Beretta GTZ
04 S60R ..Gone
Old 11-22-2011, 03:34 PM
Completes the look for me...dare to be different!
