Old 11-23-2011, 03:29 PM
usa-69z usa-69z is offline
Default Master Cylinder Sizes
Im setting up a t56 tremec into my 69 using a RAM retrofit hydraulic throwout bearing ,, IM not sure what size master cylinder to use for it? It has to be something small as i havnt much room ,, The willwood units look to be about right but do i use an 5/8 or 3/4 or 1" ?
Is there anything else to consider?
ive emailed Ram with no response.
Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 11-23-2011, 07:47 PM
BTTBSS BTTBSS is offline
The Ram web site suggests a 3/4 inch MC for their T-56 retro fit bearing, if you have a different one dig through the site and see what matches. Rule of thumb is that the Throw out bearing and MC should be the same bore. The 3/4 MC seems to be used a lot. When I bought a TKO conversion from Keisler they told me it was 3/4 but when I rebuilt it this year it was actually 7/8ths and worked
fine.
1996 Impala SS, Red Bow Tie Mod
