Old 11-29-2011, 11:28 AM
Swain's Avatar
Swain Swain is offline
Default New LSX LS1 LS2 LS3 L92 Deep Oil Pan With Baffle & Pickup Tube & DOD Bypass
This is a new oil pan taken off a L92 crate motor and never used. It has the secondary oil pressure bypass valve for Displacement On Demand engines which can be removed and the hole plugged for non DOD use. Note that it has not been drilled for the oil sensor. The oil filter bypass plate and bolts are included. The new oil pan gasket is still attached to the pan and is new and absolutely usable. The bottom of the pan has a bolt-on shield/skid plate.
Also included with this pan are a used windage tray/baffle and a used oil pump pickup assembly.
$ 80.00 shipped.
PM me questions..
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 12-09-2011, 08:50 AM
Swain's Avatar
Bump
Make an offer always good deals on fridays
Jason Swain
