Old 11-30-2011, 08:44 PM
ed1le ed1le is offline
Default ZEX EFI Wet Nitrous System
Hardly used ZEX EFI Wet Nitrous System. Part # 82023. 125HP shot. Was on car I bought but don't plan to use b/c car is also supercharged. Per previous owner, only sprayed a few times, still N2O in tank. Retails for about $600, asking $350.
Additional info available at http://www.zex.com/zx/v8-efi-wet-nitrous-system.html.
Product Description
Another universal kit designed to work with stock type engines is our V8 EFI Nitrous System. Designed to provide anywhere from 75-125 additional horsepower, this can also be installed on turbocharged/supercharged vehicles and is still only a 2 hour installation. All necessary components are shipped with the kit, including tuning jets, fuel tap fittings and a Nitrous Management Unit that contains solenoids, filters and activation electronics.
• Designed to provide 75-125 horsepower
• Uses both Active Fuel Control™ to monitor bottle pressure and a ZEX™ patented TPS switch to activate nitrous
• Ships with tuning jets, fuel tap fittings, solenoids, filters and all necessary activation electronics
Will ship but tank will be emptied prior. Thx.
1987 Iroc, ZZ4, TPIS Mini Ram, TFS heads, custom cam, T56, 3.73's, C5 brakes, 17" Centerlines, Full Hotchkis/Koni Suspenion
1970 Skylark Convertible Pro-Touring project- on hold
