Old 12-01-2011, 12:33 PM
fletcherscustoms fletcherscustoms is offline
Default 69 Camaro DSE Dash insert, by Fletchers Customs
I was asked by a customer and fellow forum member "canrc" Raj to build a custom DSE dash insert , loaded with Autometer gauges for his Camaro he is building. We used a DSE insert, loaded with 9 gauges, radio slot, and vintage air vent.
https://lateral-g.net/forums/show...&highlight=raj
The wiring was a custom harness from American Autowire, all wires use OEM style double crimp terminals, individually shrink wrapped and color coded to each wire color. Then fully routed for maximum clearance behind the dash, and allows for easy removal of the entire harness as a whole unit if need be.
The entire unit was sanded, primed, wet sanded then sprayed with a 60% gloss Matte single stage.
I wanted to show you guys another side of what we can offer here at Fletcher's Customs. These are available in any setup you can imagine, and priced very well. And the easy part all you got to do is drop in place and secure some wiring. Contact me for any more info
Here are some pics
Chad Fletcher
Fletcher's Customs and Speed
229-221-4690
[email protected]
Old 12-01-2011, 12:53 PM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
DAYUM that is sexy. Very nice man...
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 12-01-2011, 01:16 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Looks GREAT brother! I'd expect nothing less than perfection out of your shop!
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 12-01-2011, 03:26 PM
Doug1's Avatar
Doug1 Doug1 is offline
Very nice work! Top notch as always!
Old 12-01-2011, 03:45 PM
coolwelder62's Avatar
Look's great.I like the use of the clamps for routing the wire's thur.
Old 12-01-2011, 10:34 PM
canrc canrc is offline
Thanks again Chad! Dash looks great -- I hope to get it in the car soon!
Nothing but great service and advice from Chad while building the dash!
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 12-01-2011, 10:49 PM
4mm 4mm is offline
Can you PM me the price for the exact same unit minus the dash? I already have my own uncut DSE dash.
Old 12-02-2011, 05:35 AM
CornHusker4Life's Avatar
CornHusker4Life CornHusker4Life is offline
I Love the CLEAN Look
Old 12-02-2011, 06:21 PM
aany001's Avatar
aany001 aany001 is offline
I am also interested in a set up. I am looking for
5" tach
5" speedo
and 4 2 1/16 fuel,volts,temp and oil pressure.
Also need the factory ac vent and heater control cut out.
I am running an LS1 with a T56 trans
please let me know a price for a turn key set up in black for a 69 camaro.
thanks
Steve
Old 01-18-2012, 05:30 AM
Heres another leaving today headed for Canada
Chad Fletcher
229-221-4690
[email protected]
