Old 02-13-2006, 06:47 PM
cobra2547 cobra2547 is offline
Default Help the new guy drop his chevelle
OK so I would like to drop my chevelle but don't know all the parts I need to complete this.I am more of a late model mustang guy. This is what I have 71 chevelle 454 power disc brakes front drum rear recently installed. 12 bolt rear with stock control arms and ladder bar I plan on putting a set of aftermarket arms and removing the ladder bars. Here is a current picture of my car.
This is what I want in terms of ride height
so what is the shopping list going to consist of. What do I defineately need and what are some nice option that are not really needed.
Old 02-13-2006, 07:04 PM
SS454 SS454 is offline
Hotchkis springs all around for about 300.00 from Jegs. I've got a 70 Chevelle with a 454 big block and those springs give it a nice stance.
Old 02-13-2006, 08:12 PM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
Yep,a set of Hotchkis springs or Eibach Pro springs would do nicely. A good set of shocks (Bilstein,Koni,QA1) to go with those will really improve ride and handling. If you`d like to go to the next level and put together a combination to pick on BMWs in the twisties we can help you with that. www.SCandC.com Mark SC&C
Old 02-13-2006, 08:35 PM
Do you think i need a set of drop spindles or just the springs will do?
Old 02-14-2006, 07:37 AM
almcbri's Avatar
almcbri almcbri is offline
Coil Springs would work just fine for dropping your car in the front, and a good set of hotchkis rear leaf springs can bring the car down. There is a chevelle on Marcus's Sc&c website that has done some cools modifications, check it out.
Old 02-14-2006, 11:40 AM
Derek69SS's Avatar
Originally Posted by Andrew McBride
...a good set of hotchkis rear leaf springs can bring the car down...
I think you meant coil-springs
Of course, new springs & shocks like Marcus suggested, and for the rear, if you want mild, replace the bushings with new rubber bushings... if you want something more, UMI makes lower arms with QA1 spherical ends on both ends, adjustable uppers, again with QA1 sphericals... then there's Wolfe Racecraft, which makes spherical bearings that go in the axle housing also.
I bought my whole rear setup from Wolfe, but they have all solid rod-ends rather than the teflon-bushed QA1s, which would help isolate the road-noise and vibrations. Their lowers also do not allow for a sway-bar.
Old 02-14-2006, 01:00 PM
almcbri's Avatar
Derek,
yeah I was still asleep when writing that response. "Coil Springs"
