Old 12-05-2011, 04:05 PM
spacepirate spacepirate is offline
Default Header advice for my setup
Hey guys,
I just put a GM Fastburn 385 into my 68 Camaro and need some help finding headers for it. I've done a search and haven't really come up with anything definite. The problem is that the fastburn heads have a D-port shape and not a lot of guys make headers for that application. Can anyone recommend a good solution?
Old 12-05-2011, 08:31 PM
Anyone have any advice?
Old 12-10-2011, 05:42 AM
ccm399 ccm399 is offline
Howdy,
The D-Port shouldn't matter unless it has been enlarged a lot from porting (and lets hope that is not the case). Your pipe should not match your opening anyway so a round tube will be fine on a D-Port head. The only possible issue would be coverage of the port but I would guess the Fast burn heads to have smallish ports. Not a bad thing by the way...
The fast burn head has the std bolt pattern on the exhaust flange so any 23* SBC header will bolt up. Again the D port shape on this head should not effect the header selection. Without knowing any other specifics on the engine I would make an educated guess and say 1 3/4" tubes should do you well.
Chris
Checkout my '71 Pontiac Firebird Build Thread Click Here
Old 12-10-2011, 08:58 AM
Thank you Chris!
Old 12-10-2011, 11:12 PM
dead sailor dead sailor is offline
Maybe you can look for something for an lt1 car that may fit your application? I believe lt1 heads are d-port.
