Old 12-09-2011, 02:30 PM
Jay Hilliard's Avatar
Default VA GenIV installation questions
I have a couple of questions on installation/routing in a 69 camaro.
1) Per instructions, you drill a hole 1" below drain pipe. How/where did you run the drain line after? Leave it stubbed at the firewall or run it down frame rail, etc?
2) Best place to locate heater control valve?
Any help is appreciated.
Jay
Old 12-11-2011, 07:58 AM
Z06vette's Avatar
Z06vette Z06vette is offline
I ran my drain line down along the frame rail, and the heater control just off the firewall, sort of behind the fender. I ran the heater lines behind the fender & out the front over to the water pump (LS1). I am not much into having a show piece under the hood, just tried to make it neat & clean. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 12-11-2011, 11:31 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
My instructions said to drill a 5/8" hole for the drain. The 5/8" hole fit very snug around the drain hose and sealed nice. Double check that yours says 1". I drilled mine in the flat area at the base of the firewall. My hole comes out into the packet for the subframe mount the hose then just drains to the ground. If you pop the hole into the subframe mount packet you won't have to see it hanging down from the engine compartment.
I mounted the heater control valve in the cabin just off the bulkhead. Mounting it the cabin means one less wire to run through the firewall and one less thing to look at under the hood. If you want to mount it under the hood and assuming you are routing the hoses between the inner and outer fender I would hide the valve in that area.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 12-12-2011, 08:17 AM
69x22's Avatar
69x22 69x22 is offline
I drilled mine in that little flat area at the base of the firewall using a 1/2" hole big enough that the black hose fits tight and seals then used a piece 1/2" stainless steel tubing (like on your fuel lines) clamped it to the frame then attached the black hose to the tubing.
Old 12-12-2011, 02:49 PM
Thanks guys. Do you have any pics?
Jay
Old 12-13-2011, 01:38 PM
TexasDvlDog TexasDvlDog is offline
Good info...suscribed~
Armando
67 RS/SS
07 Mustang CS/GT
02 F-150 Harley Davidson
Old 12-13-2011, 09:38 PM
JMitch19's Avatar
I'll be in the garage working on the car Thursday. I'll try and take some pics and post them Thursday night.
Jason Mitchell
Old 12-20-2011, 05:23 AM
Any pics to share?
Jay
Old 12-20-2011, 08:21 AM
JMitch19's Avatar
Any pics to share?
Sorry, I didn't end up working on the car until the weekend and I forgot to get a picture.
It's hard to tell in this picture, but my hose angles slight toward the passenger side about 1.5". It needed to do this so it would come out in the subframe mount area. It's not the best picture, but I hope it helps.
Jason Mitchell
