Old 02-14-2006, 05:41 PM
kilrcam kilrcam is offline
Default Baby blower
Anyone ever run a baby blower such as a 142 or 177 weiand, any luck with it or any bad luck with it. I'm looking to add a little extra power to my chevelle. But don't want to break the bank doing so. Also i'm running e-tec 200 heads which require the vortec intake bolt pattern and weiand just came out with a 142 blower. Any help would be much appreciated. Thanks
Brad
91 camaro RS, 70 chevelle, 99 dodge dakota,
62 thunderbird, and 89 cougar
No Sympathy Racing
No sympathy for the loser
http://img.photobucket.com/albums/v6...marodakota.jpg http://img.photobucket.com/albums/v6...o/DSC00314.jpg
Old 02-14-2006, 06:53 PM
Blown353 Blown353 is offline
They are very limited as far as volume; they'll make good low end torque but not much top-end power, and you can't spin them quickly enough to make good top end power without overheating the intake charge.
Their limitations are very apparent on larger displacement engines. Even if you install one on a 350 I wouldn't expect much more than 475hp out of the combo, but it will be fun stoplight to stoplight because it will produce ample amounts of low and midrange torque.
Troy
1969 Chevelle
Old 02-14-2006, 07:47 PM
rocketman's Avatar
why not go procharger,they have carb kits know to bolt one on.or my favorite a little spray,nothing like a 100 shot of nitrous.
Old 02-17-2006, 05:31 PM
cutlasskid cutlasskid is offline
Default blower
i used the b&m 144 for 8 yrs with no problems on a 350 i think it was one of the best blowers i have tried, I raced mild built bbc and did not lose many races. I tried the procharger after the 144 and was never happy with it. the 6-71 blowers i could not keep balancers on the crank. so i think its the best bang for the buck, if you want more power just add a 100 hp kit to the top and go.
