Old 12-13-2011, 09:08 PM
usa-69z usa-69z is offline
Default ATS X-member bolts
Ive got an American Touring Specialties Xmember ready to bolt up and noticed according to instructions the side mounts bolt to the lower side of the frame rail .. Is this right? where as the original x member on a 1st gen camaro bolts to the top of the rail.
so long bolts are needed to complete the install and thread right thru the rail?
why dont they supply these bolts in the 'kit' ?
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 12-13-2011, 09:27 PM
My ATS crossmember is on top. Now that you mention it though I think I saw a drawing or instruction set for a crossmember that appeared to bolt on from the bottom and it seemed odd to me. I had assumed that was an error. I think there is a pic of mine installed in my build thread
John
'71 Nova (Build thread)
FFR Roadster
Old 12-14-2011, 10:51 AM
rchaskin's Avatar
rchaskin rchaskin is offline
On top of the frame rail.
see link
http://www.americantouringspecialtie...s/files/10.pdf
Good Luck.
My crossmember is quite bouncy. I am going to add some gussets on the plate to the down tubes.
Old 12-14-2011, 07:42 PM
GeoffP GeoffP is offline
I have the previous design to this but it has very similar frame mounts - they bolt to the top side of the frame. I'm glad I got the first design. It's non-adjustable but appears to be a much stronger design. Mine doesn't move at all.
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 12-14-2011, 09:02 PM
see link
Good Luck.
strange , this link clearly shows it to sit on bottom of frame rail???
Old 12-14-2011, 09:08 PM
John , it does look like yours is bolted to the bottom of frame as well. I guess thats where it goes.. I just dont get why they dont supply bolts for this if all others are included. No big deal otherwise i guess.
Gav
Old 12-14-2011, 09:23 PM
Mine is between the subframe and the floorpan which I consider to be the "top". Sorry if the pic was confusing or unclear.
John
FFR Roadster
Old 12-15-2011, 05:53 AM
rchaskin's Avatar
look one more time.
You cannot see the bolts in the picture.
also notice how the bracket is tucked in the pockets of the floorpan.
It is confusing. I can email you an installed pic if you need one!!
Randy
Old 12-15-2011, 06:22 AM
look one more time.
Randy
Ah maybe im missing something here??? so the brackets are bolted to the top of frame and it sits that high??
Old 12-15-2011, 06:51 AM
rchaskin's Avatar
Yes.
It misses the floorpan by like 1/2".
But it does fit.
See this pic. It is a 70 camaro, but it mounts similarly.
http://www.hotrod.com/techarticles/e.../photo_10.html
