Old 12-14-2011, 11:20 AM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Default Automatic transmission ideas
Hey guys. I'm in the process of putting my drive train together on my 69 Camaro and I was trying to figure out which way to go. Since converting to a T56 isn't in the cards this year, I was looking at the 700R4, 2004R or 4l60E.
Which is the most logical to go with regarding cost and conversion man-hours?
I am running a 454 that will put out about 425 hp to the crank, and the car currently has a TH400.
Thanks.
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 12-14-2011, 12:07 PM
rjsjea's Avatar
rjsjea rjsjea is offline
http://twistmachine.com/Manumatic_Systems.html
Probably not the most cost effective, but pretty cool setup
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 12-14-2011, 12:35 PM
realcoray realcoray is offline
A 4L60e (or 4L80e) would probably cost the most because it sounds like you'd need the computer to run it.
I would suggest 4L80E using a controller, but buying a used one and installing a shift kit or having it rebuilt. This is by far stronger than the other options, and you don't need a stage x rebuilt one, a basic rebuild and shift kit will handle your car without breaking a sweat and end up being a lot cheaper.
