Old 12-14-2011, 11:55 AM
narlee narlee is offline
Default Coil Overs On Driver
I have searched the forum and found a lot of information on coil overs. I have a 69 Camaro that will be a driver, not a cruise downtown driver but a jump in and go anywhere no matter how far driver. I want to set it up to ride well and handle very well and research seems to show to get the handling with a leaf spring set-up the ride suffers. This brought me to coil overs, is there any problems with running them (all 4 corners) on a everyday car? Interested in knowing about reliability, noise, or quirks that would show up that would need to be taken into account. Thanks.
Old 12-14-2011, 12:33 PM
The one thing with coil overs is that they can have a lack of travel. So in a daily driver - where you might tend to want to have a full tank of gas -- load up the trunk with luggage and then 4 people and off you go.... you can be bottoming out. I stayed with leaf springs on my new chassis in my '37 Ford for this very reason.
Coil overs are "tunable" for height (like plus or minus about 1/2" or so up and down) and most use them for ride height over the ride "quality". On cars that are going to be used to "handle" -- this is the system to go with. But Mary Pozzi was a National Champion auto crosser and her car used leaf springs!
My brother in laws '69 Camaro -- pro street -- is on leaf springs and I'm trying to get him to switch to coil overs -- it "cleans up" the rear end area and makes the car appear a little more 'modern' and we can then adjust ride height and get it really dialed in... but his car works just fine with leafs.
If your going to make your car a really nice handler - bring it up to 'date' - improve the resale - etc -- then coil overs would help in all of those areas... but I'm just saying that they aren't "required" to give you a good ride or handling. SPRINGS really just hold the car up... and leaf springs hold the rear end into position (side to side loads). It's really more important to get these springs "right" for the weight and use regardless of whether or not they're coils or leafs. It's just easier with coils.
Look at SpeedTech - or DSE - or BMR - or other manufacturers - they all have kits for conversions etc. Then it's a matter of budget and what you want to do.
Old 12-14-2011, 06:03 PM
Thanks for the response. From what I understand to get the same handling out of leaf springs the ride begins to suffer. There are several interesting coil over packages but I haven't found how they hold up. I don't want to find out too late there long term issues.
Old 12-14-2011, 06:08 PM
In all my years - I've never heard a single complaint about coil overs. They're a marvelously simple shock and spring... I would however - stay away from QA 1's --- Strange makes a far superior unit. Amazing really how much my Nomads ride improved when I changed over to Strange from QA 1's.
Old 12-14-2011, 06:54 PM
ccracin's Avatar
ccracin ccracin is offline
Good info Greg. You can get around bottoming with longer free length springs and longer stroke shocks. The problem with retro-fits is packaging. Most don't want to make the compromises and do the fabrication it takes to put the longer package in. You can do it on a first gen, but the top coil over mounts would have to be in the trunk without making the lower mount too low. I believe Steve Rupp and the Pozzi's did this to Bad Penny. Just food for thought. Also as Greg said, leafs are nothing to turn your nose up at. Especially if you use purpose built performance leaves and properly tuned shocks. Great ride and handling with very little fabrication. I don't want to confuse you narlee, but there are several ways to get where you want to be. Oh, and durability is not an issue with either setup. Don't sweat it! Good luck!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 12-14-2011, 08:00 PM
This is the type information I was looking for. I hadn't seen anything about bottoming out previously. It makes sense it could be a problem if there isn't enough travel. Thanks.
Old 12-14-2011, 09:23 PM
The only reason they bottom out is due to folks getting greedy with the adjuster wrench. Keep a shock in it's sweet spot with the correct spring rate and you won't have any problems. 50/50 shock travel available for compression and extension. If you want to go lower, modify your shock mount and you can still keep it in the sweet spot.
Personally, bottoming out a coil over with a jounce bumper is not any worse than hitting a bad bump with leaf springs.
Old 12-14-2011, 10:34 PM
jamesinark jamesinark is offline
Default QA1's vs Strange
Right now I'm in the setup and configuring suspension geometry (changing pickup points for control arms and such) on my second gen Camaro RS.I have finally settled on the rear suspension setup (a Torque arm that I am currently fabbing up).My question is directed to Greg as in what did you find to be some of the upsides to the Strange c/o's as opposed to the QA1's?I am currently going to be using the Strange 12 bolt rear housing and most of the internals will be strange.Anyway I was really thinking about using the Strange coilovers and couldn't find a comparison between the two.It seems as if most of the guys on here are using the QA1 c/o's and then I read something that Frank Savitske(I hope I spelled it right) wrote concerning them and touting Afco shocks instead.I think that the Strange c/o's seem to be of high quality and not to shabby a price.That is very important when something like Penskes are a little out of reach if I want anything else done to the car.Any info about the reasons you found them to be a better choice would be greatly appreciated.Thanks!
Old 12-15-2011, 05:03 AM
Supporting Vendor
I suggest you look at our new impact forged, monotube, Fox Racing Shox based coil overs:
http://www.ridetech.com/store/coil-overs/
If you've seen the Ford Raptor pick up truck you've seen the same parts and technology that's in our units, and Ford certified them to over 100K miles.
Our coil overs are tested past 300ips (inches per second) shaft velocity, which is WAY more then you'll ever see on the street. As an example a pothole will typically provide around 50ips. So you can be assured even if you hit something really, really hard the shock will not be the point of failure!
Pair these shocks with a set of very high quality Hyperco springs and you've got a killer combination. The Hyperco springs use high tensile steel which results in less coils for a given rate. This means, even on short strokes, you have more room between the coils, so you are less likely to reach coil bind before the shock bottoms out.
Skunk Werks
Ridetech
www.ridetech.com
Old 12-15-2011, 07:55 AM
bret's Avatar
bret bret is offline
Supporting Vendor
I have the Triple Adjustable coilovers on the 48 Hour Camaro with a 600# spring in the fron and a 250# in the rear. I'm using a stock front subframe and our bolt in 4 link in the rear. I must say, the car rides beautifully...much better than my Z06, approaching my CTS V Cadillac. And that is with a 35 series tire!
I would not necessarily recommend the triples for a daily driver...no need for all that hardware or expense...the NA or SA shocks will do everything you need, and then some.
Keep asking around...I know there are a few guys on this forum with the RideTech coilovers who can offer an opinion on ride quality...
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
