Old 02-15-2006, 07:35 PM
chevzilla396 chevzilla396 is offline
Default some turbo questions
if i wanted to make some where between 800-1200 hp what set of turbos should i use? maybe a garret gt37 or a gt40 or maybe some turnonetics t-4s?
any other turbo info would be awsome too
-JT
-JT
Old 02-15-2006, 08:11 PM
or maybe 2 garrett gt35r's
-JT
Old 02-16-2006, 04:39 AM
Speedster's Avatar
Speedster Speedster is offline
Call Tom Nelson at Nelson Racing Engines. He is a turbo guru.
(818)998-5593
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 02-16-2006, 07:20 AM
I assume from your sig the motor is a 396 big block. Lots of air flow there so getting 1000hp shouldn't be to hard. I would say at least a 70mm twin setup. If your wanting to go with a single I would suggest a GT47 - 88mm.
Checkout Precision Turbo - Harry is a god in the turbo world.
Jeff Allen
J2 Speed and Custom
Old 02-16-2006, 03:51 PM
nitrorocket's Avatar
Twin 70's are a little to large for only 1000 hp in a street car. Twin 50 s are good for about 1500 hp! You want to choose the smallest turbos that will do what you need to have maximum low end power. A 60-1 or 60-1 Hi-fi will be perfect. They are also VERY small. I am making about 900 hp right now with a baseline tune and pumpgas. The tubing is only 2" coldside and a 3" inlet! This makes routing tubing very easy and compact.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 02-17-2006, 12:57 PM
hotwheels's Avatar
hotwheels hotwheels is offline
i totally agree...........if you want, contact joe at www.boostedsystems.com he has some of the best turbo price's i have ever seen.
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
