Old 12-30-2011, 05:06 PM
patriot68 patriot68 is offline
Default t56 no 2nd,3rd, or 5th help
i have an 02 ls1 t56 in a 68 camaro. got in yesterday and no 2,3, or 5.
drove it for a couple of miles and it started working perfect.. same thing happened today. the trans has 4000 original miles on it. ive put about 100 miles on it myself. any help would be appreciated. its full of fluid
scott
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
Old 12-30-2011, 05:19 PM
intocarss's Avatar
Found this...
"Fairly common problem with T56's. You either sheared the teeth off the cluster gear and main shaft for 5th and 6th, or you have a broken shift fork/shift pads".
Since you didn't loose reverse, it sounds like the mainshaft. Time for a teardown and rebuild.
Old 12-30-2011, 06:11 PM
Sieg's Avatar
Sieg Sieg is offline
Trans come out of a wrecked car? That may explain internal stress related damage that is now coming to the surface.
Old 12-31-2011, 01:53 AM
70rs's Avatar
70rs 70rs is offline
scott
You drove it a few miles and then it started working in all gears? Very strange!
Did you fill it with Dextron lll fluid? It's a manual trans that uses ATF. Sounds weird but it's true. If you didn't use that fluid it can and will cause shifting issues.
Eric
Old 12-31-2011, 05:36 PM
yea i put dextron in it. drove it today with no issues
