Old 12-31-2011, 11:45 AM
69Camaro's Avatar
69Camaro 69Camaro is offline
Default AMD deep wheel tubs or DSE?
I was looking for a trunk floor and related sheetmetal on the AMD website and found these:
https://www.autometaldirect.com/stor...-(6---Wide)-LH
https://www.autometaldirect.com/stor...-2---Minitub-L
I was intending on ordering the Detroit Speed tubs.
http://www.detroitspeed.com/1967-196...deep-tubs.html
Just wondering if anyone has used the AMD stuff and how it compares to the DSE. If the DSE tubs are a better product then I will order them as planned.
Thanks for the advice,
Jayson
1969 Camaro
Kore3 Z06 brakes
Hydratech hydroboost
Wilwood master
Ridetech stage 2 with truturn
Forgeline GA3 18x9.5/18x12.0
BFGoodrich Rivals 275/35 & 335/30
Magnum T56
Lots of AMD sheet metal
Sprinkled with DSE parts
Ididit Steering column
GM 376/525hp crate
Moser 12 bolt, tru-trac, 3.73:1
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 12-31-2011, 04:56 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
So does the AMD one come with the inner AND outer? It looks like it in the description??
Autokraft
Old 12-31-2011, 05:32 PM
69Camaro's Avatar
From what I can see on their website, you can get them both ways. I was looking at the pair as I suspect my outers are just as bad as the inners. I'll be replacing both anyway.
1969 Camaro
Kore3 Z06 brakes
Wilwood master
Magnum T56
GM 376/525hp crate
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 12-31-2011, 07:34 PM
Musclerodz's Avatar
that is a dynacorn minitub. the x in the part numbers denotes it is not made by amd. they are slightly narrower than dse i beleive
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-31-2011, 08:35 PM
Lateral-g Moderator
DSE tubs are the way to go. That is probably the one part that everybody uses, no matter what camp there in.
Old 12-31-2011, 08:38 PM
camaro41701 camaro41701 is offline
The Dynacorns are not as wide as the DSE tubs are.I think they are 3/4 inches smaller than the DSE.
Old 01-01-2012, 09:53 AM
69Camaro's Avatar
Thanks guys, that"s all the info I needed, I'll be sticking with the DSE stuff!!
1969 Camaro
Kore3 Z06 brakes
Wilwood master
Magnum T56
GM 376/525hp crate
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 01-01-2012, 03:12 PM
bigtime's Avatar
bigtime bigtime is offline
I have them on my car with 335's and have room to spare.
Bob
Old 01-01-2012, 04:05 PM
69Camaro's Avatar
Just to be clear, you have the AMD(Dynacorn) tubs or the DSE?
1969 Camaro
Kore3 Z06 brakes
Wilwood master
Magnum T56
GM 376/525hp crate
Speedhut Guages
Vintage Air
Corbeau LG1’s
Digi-tails
Ringbrothers
Harwood cowl
Old 01-01-2012, 04:32 PM
bigtime's Avatar
f
Yes I have the dynacorn ones
Bob
