Old 01-07-2012, 11:13 AM
fultz1275's Avatar
fultz1275 fultz1275 is offline
Default Are GM rearends notoriously not centered?
I just installed a new rearend in my 68 chevelle. it is offset to the passanger side by about 1/8". I called DSE to ask them the best way to center the rearend considering im using their upper and lower control arms. They said the GM rears are rarely centered and there is typically less tire clearence on one side verses the other. They said not to worry about getting it perfectly centered. Can anyone confirm this to be the case with GM rearends? Should I expect to have it offset to the passenger side by about an 1/8 inch.
Old 01-07-2012, 11:36 AM
SLO_Z28 SLO_Z28 is offline
Yes, they are. Even the new vehicles are that way. Its not unheard of to have a rear end 3/4's of an inch off center in a GM muscle car.
James F.
1974 Camaro Z28
Old 01-07-2012, 02:06 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Slo-Z is right. It is common to see them off center
Autokraft
Old 01-07-2012, 03:48 PM
intocarss's Avatar
Yup mine is over to the right.,.Drives me nutz
Old 01-07-2012, 06:18 PM
WILWAXU WILWAXU is offline
Yup.. I had to go with a 1.5" spacer on the drivers side and a 1" spacer on the passenger side to get 275/40 17's on the back of my Nova.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 01-07-2012, 07:06 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Yep, drove me nuts too. I had a 12 bolt that was off center to the right and my right, rear wheel was closer to the lip on the quarter panel than the left was.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 01-08-2012, 07:46 AM
drc270 drc270 is offline
My 12 bolt is off 1/4" also. I am getting ready to pull it and have it rebuilt.
My plan is to remove and replace leaf perches accordingly to center the
housing. Is this the best way to correct issue?
Old 01-08-2012, 07:33 PM
fultz1275's Avatar
Thanks for all the feedback guys.
Old 01-09-2012, 04:45 PM
The WidowMaker's Avatar
it may be more than just the rear if you have a full frame car. my body properly aligned sat 1/4" closer to the frame on one side than the other. frame checked out on all measuerments, but they allowed for a lot of "slop".
"The WidowMaker"
Old 01-21-2012, 09:48 AM
LUACE LUACE is offline
this just makes things more complicated. I am about to narrow my rear end. Should i not narrow 3 inches on both sides? is there a chance I may need 3 inches on one side a 2 3/4" on the other, to get it properly centered? what would be the proper way?
-Louis
1967 RS/SS (driver)
1968 RS/SS (project)
