Old 01-08-2012, 04:09 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Default Steering Wheel Adapter for GM-Air Bag Column to non-Air Bag Steering Wheel
I am planning to use a 4th Gen Camaro Steering column in a first gen Camaro. I'd like to keep that column and use it for the wiper motor controls, cruise control, horn and other existing features on that column. I'd like to use an aftermarket steering wheel, one not set up for an air bag, however when I went to the Good Guys show and asked around, nobody had heard of an adapter for an Air-bag factory/OEM type of column to a non-air bag steering wheel.
Anybody have a solution for me that doesn't involve buying a whole new column?
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 01-08-2012, 05:50 PM
intocarss's Avatar
You mean something like this??
http://www.ebay.com/itm/MOMO-Steerin...item1c2298ecc1
Old 01-08-2012, 07:59 PM
DETON8R's Avatar
Default saw it, don't know if it works though
Thanks for that post, not much explanation there in that listing. Might work, hope there is a good return policy.
I saw that one and another, can't remember who made the other one, another big steering wheel maker. I'd like to know if anybody ever used them, and if the horn button works too.
Old 01-08-2012, 10:31 PM
intocarss's Avatar
Here's another Co with a hub. At least you can call this place and get some info.
http://crowderscustomizing.com/catal...o_69-1181.html
I do know on Pro Touring .com there was a guy with a 69 Camaro with a 94 steering wheel on it. opposite of what you're doing but it fit.. I had a 81 Camaro steering wheel on one of my 68's. Hope this helps
Old 01-09-2012, 12:11 PM
Swain's Avatar
Swain Swain is offline
Check with Lecarra 800-432-8170
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
