Old 01-08-2012, 05:49 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default If I don't want to use a muncie what are my options?
I need a new tranny but I don't want to I with a Muncie again. I think the engine I have now (350) has too much power for the four speeds. What can I swap in to give me a couple more gears and handle a little more. Also I don't want to have to do a ton I fabrication.
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 01-08-2012, 07:10 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
How bout a 6-speed?
Autokraft
Old 01-08-2012, 07:19 PM
jcal87's Avatar
Lol yea but I don't know what kind would be a direct fit. Also is there anything that can later be used with an ls motor if I choose to go that route?
1968 Camaro Blue
Texas A&M Alumni
Old 01-08-2012, 08:21 PM
Flash68's Avatar
Flash68 Flash68 is offline
I highly doubt your 350 has too much power for your Muncie. Power they can hold pretty well.... but their linkage system is not great for quick shifting.
A T-10 is a good option if you don't need overdrive and should be a direct fit. There is one in the for sale forum I just saw for under $1000 fresh.
How much power do you have, what are your intentions with the car, and what is rear end gear ratio?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-08-2012, 08:46 PM
jcal87's Avatar
I'm not too sure how much power the engine is pushing its roller camed...The had the muncie on it but the case cracked.I figured this was just due to too much torque. Gearing as it sits right now is 4.10 but i do what do drop this down to a 3:73 or so. Later down the road I would like something more along the lines of pro touring.
1968 Camaro Blue
Texas A&M Alumni
Old 01-21-2012, 11:49 AM
Tweaked Zed's Avatar
Tweaked Zed Tweaked Zed is offline
Ya. Just put a T56 in it and call it done. I should work for Tremec....Lol. Can't say enough good about that trans.
1969 Camaro SS, Maggied LS2, T56, Fab 9, G-Link, Speed Tech sub, Fikse FM10s....sold
1963 Nova SS, 383sbc, 700r4, 3.73 8.2, CPP 4wdiscs, Cragars, mostly driven by the GF.
1973 Camaro RS, 454 BBC, T400, 3.73 8.5, newly acquired full resto, next PT project.
1995 Camaro Z28, 440ci SB2.2, T56, 9", PB 9.70 @ 142mph - 2011 Hot Rod Drag Week 2nd place BB/NA
2009 TBSS 2WD 3SS, cam, exhaust, 450rwhp DD.
Old 01-21-2012, 11:56 AM
jcal87's Avatar
Can I use it on an ls motor in the future?
1968 Camaro Blue
Texas A&M Alumni
Old 01-22-2012, 08:46 AM
TT302Z28 TT302Z28 is offline
If you get the LS based T56 and not the LT1 version.
BTW.....even GM put the Muncie in high horsepower applications.
Old 06-23-2013, 10:41 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
You can run a Super T-10 .Or the 5 or 6 speed of your choice.
