Old 01-10-2012, 04:19 AM
GMracer's Avatar
GMracer GMracer is offline
Default Welding Steel Tubing to Sheetmetal
I've seen it done before and curious about the correct method behind it. For instance some of these full frame cars will have a 4x2 .120 wall tubing welded the to rocker to accept the sheet metal floor, which all gets welded together. I have a project I'm working on that I would like to incorporate a tube frame into the rockers for additional strength.
Could anyone enlighten me as to the correct method behind this?
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
Old 01-14-2012, 12:05 AM
Vince@Meanstreets's Avatar
concentrate on the thicker/larger metal and let it flow to the thinner stuff.
practice practice practice also its good not to have a large gap between the two.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-14-2012, 09:26 PM
Yep -- What Vince said..... heat on the thicker piece and it will "incorporate" the thinner metal with just the slightest movement of your hands... this is were skills come in.
Old 01-15-2012, 03:59 PM
GMracer's Avatar
Ok, I figured as much, and thats the method I've used previously, but wasnt sure if there were any specific trick I should practice to make sure everything was penetrated properly. Thanks!
Nick Schiffer
Special Thanks to:
