Old 01-12-2012, 05:45 PM
ricer ricer is offline
Default 1st gen F-body drop spindle
I have searched everywhere and can't seem to find the answer. I am looking for a 2" drop spindle that will work with the 12" wilwood brake kit. Nothing fancy (ATS, a billet piece, etc) just a spindle that will work and relatively inexpensive. I have read fatman's are garbage and heidts maybe the best ones to use if they will work. Any inputs or other suggestions?
565 twin 80mm 67 Firebird
545ci FFR MKIII Roadster
Old 01-12-2012, 06:01 PM
v8s only's Avatar
v8s only v8s only is offline
Default rideteck
rideteck http://www.ridetech.com/store/components/spindles/
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 01-12-2012, 06:11 PM
coolwelder62's Avatar
Call Darren at Ride tech.Their product's are 1st. rate.
Old 01-12-2012, 08:38 PM
Ron in SoCal's Avatar
I cold be wrong, but isn't Ridetech sourcing Fatman spindles in their set up? I know they used to...
Ron in SoCal
69 Camaro in progress
Old 01-12-2012, 10:51 PM
David Pozzi's Avatar
Ride Tech has it all worked out. Most drop spindles will place your steering arm 2" lower than it is now and that usually causes contact between the tie rod end and the tire or rim. Ride Tech has the Tru-Turn system that raises the steering arm out of the way.
David
http://www.PozziRacing.com
Old 01-13-2012, 07:04 AM
so who else besides Ridetech? just curious
i have a smithcraft front sub/arms so i have to make sure these will be compatible.
Old 01-13-2012, 09:40 AM
Blake Foster's Avatar
Does the Smith racecraft sub not use a front steer Rack?
Blake Foster
www.speedtechperformance.com
Old 01-13-2012, 09:50 AM
it does use a front steer R&P. I spoke with Smith and the ridetechs will work, and just trying to see what all my options are in terms of drop spindles.. the sub looks just like this
http://srdparts.com/index.php?page=s...emart&Itemid=1
Old 01-17-2012, 05:59 AM
wound up ordering the ridetechs, everyone says they will work so we will see i guess
Old 01-17-2012, 08:31 AM
Supporting Vendor
Looks like they use a stock F-Body spindle and use a custom steering arm for the R&P. Our spindle will be fine as it's a direct replacement for the stock unit.
Skunk Werks
Ridetech
www.ridetech.com
