Old 01-14-2012, 05:21 PM
Track Junky's Avatar
Default Lost my motor today
Well after 155,000 hard miles my 2001 Siverado lost #7 piston. I fired it up this morning and I noticed it had a miss. Took it to the shop cause I had to smog it anyways.
They noticed the misfire and then did a compression test. good all around except for cylinder #7 only giving 70 lbs of compression. Pulled valve cover to check valve springs and they were fine.
By Wednesday and $5600 later she should have a new motor in her.
OUCH!!
Gaetano Cosentino
Old 01-14-2012, 06:10 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
The low compression could be froma bad valve. I work for gm, on the heavyline side, and very rarely that stock engines loose pistons or block damage. I see more often on 4.8, 5.3, 6.0 is a valve seat burnt. I have 2 6.0 and a 5.3 with burnt valves on the floor nxt to my tool box. One actually has a burnt exh valve on cyl #7 lol. What I'm trying to get at, hopefully they did a leak down test also, and not just going on a compression, could save u money.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 01-14-2012, 06:28 PM
Ron in SoCal's Avatar
Wow Gae...I read that headline and thought it was your race motor. Painful, none the less, but glad it wasn't that!
Ron in SoCal
69 Camaro in progress
Old 01-14-2012, 06:47 PM
Sieg's Avatar
Sieg Sieg is offline
Bummer! More fun spending motor money on track toys vs. transportation tools. Guess the upside is it's not a Duramax.
Old 01-14-2012, 07:10 PM
intocarss's Avatar
That sucks, Sorry to hear it
Old 01-14-2012, 09:32 PM
CarlC CarlC is offline
Thanks for the practical side of this. It's always good to know what the long-term weaknesses of a system are.
In that light, at 155k how is the overall condition of a well maintained 5.3 - 6.0 that sees little towing/heavy-duty use? My wifes '05 5.3 Silverado 1500 runs like a watch, does not burn oil, and has had zero problems, so I'm hesitant to sell it. The instrument gauges are another story.
http:www.vaporworx.com
Old 01-14-2012, 09:35 PM
Flash68's Avatar
Flash68 Flash68 is offline
Yeah me too! Sucks both ways....
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-14-2012, 09:36 PM
Flash68's Avatar
Carl, your wife drives a truck? That's pretty tough...
2014 4 tap Keezer
Old 01-14-2012, 09:40 PM
We don't give a **** about your old wore out truck.
Old 01-14-2012, 10:21 PM
Good point. Didn't ask them about a leak down but to be honest I'm tired of hearing the old piston slap problem the 6.0's had at cold starts. I was told this problem has been fixed. Any insight?
[quote=Ron in SoCal;389732]Wow Gae...I read that headline and thought it was your race motor. Painful, none the less, but glad it wasn't that![/quote
You and me both buddy!!
Gaetano Cosentino
