Old 01-15-2012, 03:30 PM
usa-69z usa-69z is offline
Default ricks tank OHMs ?
Guys , im just ordering a set of guages for my 69 camaro and am not sure what fuel guage to order.. Its all the different 'ohms' these come in (autometer)
I have a Ricks vaporworx efi tank in place with the supplied sending unit being used.. can anyone send me in the right direction with what to order ?
thanx, Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 01-15-2012, 03:56 PM
camcojb camcojb is offline
I would assume they use the normal 0-90 ohm GM sensors. But you know what can happen when you assume. It would make sense since that's what the cars they make tanks for would have used.
Old 01-15-2012, 03:59 PM
Most of these use VDO senders - 0-90 ohms is pretty "standard" these days.
Old 01-15-2012, 04:33 PM
Since it's a vaporworx I'd ask Casanova. A standard ricks takes a 90
Old 01-16-2012, 03:26 AM
thanx guys , 90 it is ! (i found the reciept from purchase)
Old 01-16-2012, 08:29 PM
CarlC CarlC is offline
If you have to buy a gauge I suggest, if Autometer is on the list, the progamable version. It allows more flexibility than the standard gauge so future changes/programming are easy to deal with. I've had great luck with mine using it in multiple modes.
http:www.vaporworx.com
