Old 01-15-2012, 05:51 PM
bighus bighus is offline
Default Opinions on disc brake kit
I have a 68 camaro with 4 wheel drum brakes with a 10 bolt rear end. I've looked at several different companies a lot of them are similar. Ricks camaros has a 4 wheel disc brake kit that included everything for around $1,000. Iv read on here of several people going to corvette brakes but im pretty sure thats out of my price range. so my question is what are your opinions on ricks kit and are there any other kits you would recommend?
Old 01-16-2012, 06:36 AM
bobcat68rs bobcat68rs is offline
Default brake kit
For a budget kit give MP Brakes a look and service is very good. I use them in my shop.
Robert
Old 01-16-2012, 09:01 AM
hud697's Avatar
hud697 hud697 is offline
Like everything else it depends on what you want. You can go with factory stuff cheap. If you're going with big wheels and want big brakes, you're gonna have to pony up a bit. There's a guy on eBay that sells a front kit with drop spindles and vette rotors & calipers for $700ish
Old 01-16-2012, 08:53 PM
Gatekeeper's Avatar
Gatekeeper Gatekeeper is offline
I'm going to try the DBA 5000 slots for the front and the 4000 slots for the rear with the C6 Z06 calipers. It should do what I need it to do.
Gatekeeper
Old 01-17-2012, 09:18 AM
Apogee Apogee is offline
For a tight budget, have you considered just going with an OE style disc/drum setup? There's nothing inherently wrong with drums in the rear...in fact, they make an excellent parking brake, better than most integral caliper options by a long shot.
As for your existing drum spindles and hubs, those potentially have some value to someone looking to do a C5/C6 Corvette brake swap.
Tobin
KORE3
www.kore3.com
Old 01-20-2012, 07:32 PM
Are there any companies that stand out in doing a c5-c6 swap?
Old 01-20-2012, 10:51 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Yes, the guy in post number 5 (Tobin from www.KORE3.com) Do not be scared to give him a call, he will tell you all you need to know with good pricing also.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 01-21-2012, 08:23 AM
Thanks, I'll give him a call
