Old 01-16-2012, 01:36 PM
BANKO's Avatar
BANKO BANKO is offline
Default Using 2 RHT Tube Adapters on Suspension links?
When building custom suspensions links, is there a disadvantage to using 2 RHT or LHT tube adapters instead of 1 of each? The link length will be pre-adujsted and don't see a need to adjust it while on the car.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
Old 01-16-2012, 02:54 PM
Bryce Bryce is offline
If you use two RHT then you have a finite adjustment. You can only adjust the length to every 1/4 turn of a rod end. If you are using 3/4-16 thread than you will have an adjustment every 1/64 of an inch. Which is well within the tolerance of a suspension link.
Old 01-17-2012, 05:15 AM
Ooops, your adjustment would be every half turn, so your length accuracy would be to the nearest 1/32 of an inch.
