Old 01-24-2012, 08:07 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
Default Moving leaf spring perches on 67 camaro
Does anyone know how far to move the leaf spring perches in when using Speedtech billet offset shackles. I have a set and the installation instructions have no info about how far to move them in. I know the stock rearend is 42-1/2" on center.
Old 01-24-2012, 09:18 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
The easiest thing to do is remove the rearend and then reinstall the springs with the stock shackles. Measurements from leaf spring pin to pin or inside spring to inside spring. Remove the stock shackles and install the off set shackles and measure pin to pin or inside spring to inside spring and do the math. Just guessing it will be around 7/8" to 1" each side.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 01-25-2012, 12:42 PM
Figured that is what I will have to do...... But I was hoping somebody might know , so I could get the housing done while I was waiting on my leaf springs to come back ......
Old 01-25-2012, 01:36 PM
Chicken Louie's Avatar
Chicken Louie Chicken Louie is offline
Give Blake a call at Speedtech
Old 01-25-2012, 01:58 PM
Did that , said to put the rearend in the car and go from there..... I was hopin somebody had some experience with it.
