Old 02-18-2006, 06:43 PM
RickM415 RickM415 is offline
Default So I Started My Turbo Build...
So Can Both Turbos Be Fed Out Of The Same Oil Line And The Return Can It Be Y-ed Too ?
How About An Intercooler....2 In And 2 Out Or 2 In And One Out ? Whats The Difference ?
Old 02-20-2006, 06:35 AM
I would pull separate oil lines to the turbos just my opinion.
On the IC you can do whatever suits your plumbing needs. The difference will be in the IC core and the amount of pressure drop you'll have. The piping and routing doesn't affect much.
Jeff Allen
J2 Speed and Custom
Old 02-25-2006, 08:41 AM
hotwheels's Avatar
hotwheels hotwheels is offline
on my twinturbo's car, i came off of where the oil pressure sensor was, i have one line from there, to a "T" and then a line from there to each turbo.......
no, each line need's to be atleast 5/8" hose and each need's to be set up to free drain to your oil pan.....I know it will take extra effort, but it really need's to be done this way.....
2 in and 2 out will be alot of extra pluming........on my car, i went with 2 in, and 1 out.......so my turbo compressor side feed's in at the bottom of my intercooler and the air out, leaves the top and goes to my engine from there......For some simplicity, i would do the 2 in and 1 out......
hotwheels
1992 mustang gt twinturbo'd
1988 mustang gt bottlefed
2004 mach 1 resting in garage
1989 mustang coupe 4 cyl.
1980 mustang coupe 4 cyl.
MY MUSTANG ENTHUSIASTS SITE
Insanemustangs
Old 02-25-2006, 09:18 AM
Thanks Guys For All The Info
