Old 01-27-2012, 10:17 AM
turboapex turboapex is offline
Default 6L90 transmission
I have a 6L90 trans with tailhousing to use a driveshaft , can it be used behind a LS-9?
Thanks Mike.
Old 02-03-2012, 11:37 AM
DETON8R's Avatar
DETON8R DETON8R is offline
Default CTS-V and ZL1 use it (or will...)
Check out this article, the ZL1 will use the 6L90E auto transmission.
http://www.autoweek.com/article/2011...NEWS/110909865
from the article:
Likewise, he stressed that the optional six-speed Hydra-Matic 6L90 automatic gearbox is “not for poseurs who don't know how to shift.” As a general rule, hard-core enthusiasts will choose the six-speed Tremec manual transmission, but at least the auto 'box is built for performance, with three different driving modes including a manual setting that only shifts when a driver commands. Automatic upshifts will not occur even at redline, and Oppenheiser promised that it will select and hold the appropriate low gear into corners to match the manual-equipped ZL1's performance.
“Contrary to what we could have done [by taking the easy way out with a simple, off-the-shelf transmission], the automatic is not a compromise,” he said. “We spent a lot of time working on it for the track.”
And they are already used in the Cadillac CTS-V.
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
