Old 01-27-2012, 10:29 AM
turboapex turboapex is offline
Default LS-9 transmission ?
Which one can you use?
Old 01-27-2012, 11:58 AM
hifi875's Avatar
hifi875 hifi875 is offline
a 6l90e will work. my father in law ran one for a while in his chevy II, but it was huge and you have to run low numeric gear ratio because of the gearing in the tranny. a 3.89 was too much imo. ended up taking it out and going t56 magnum. so much more enjoyable!!
Old 01-27-2012, 01:09 PM
Thanks for the info.
Old 04-08-2012, 04:45 PM
morris69 morris69 is offline
What did u end up going with. I have a ls9 and want to run an automatic
Old 04-13-2012, 01:11 PM
So ur ls3 with the charger. Has more power than a ls9. I have a 1969 camaro
Old 04-13-2012, 02:33 PM
Stielow's Avatar
Stielow Stielow is offline
I'm running a T-56 modified by D&D Performance and it has work great.
My LS9 in now 427 CID and makes 830 ft*lbs.
Stielow
Old 04-13-2012, 03:41 PM
camcojb camcojb is offline
Stielow
yeah, but you baby your stuff.
Old 06-23-2012, 05:08 PM
carfuss carfuss is offline
Anyone try Rockland Standard Gear's Tranzilla? They claim it will take 1,200 hp and 1,000 ft/lbs.
Old 06-23-2012, 07:34 PM
Stielow's Avatar
My new engine should hit 900 ft*lbs. I'm using a TR6060 this time.
D&D Perf built it and I'm sure it will work great.
Mark
Old 06-25-2012, 06:42 PM
John at Speartech has been doing the 6L90 for while and has had good luck with them so far.Anybody with more info why to or why not to use a 6L90 trans?
