Old 01-28-2012, 04:12 AM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default 1997-2004 Corvette PowerSlot Frt & Rear Rotors Slotted Cyro Set Hawk HP Plus Pads
1997-2004 Corvette C5 PowerSlot Front & Rear Rotors Slotted Cyro Set Front Rear Hawk HP Plus Brake Pads
Centric-Power Slot Brake Rotor Features:
Perfect for track-day club racers, spirited street motoring
The ideal compromise between performance rotors and a big brake kit
Custom crafted for your specific year, make and model vehicle
Cryogenically treated to a blistering -300°F for extreme tension strength and total warping resistance
Cycled between -300°F and 300°F three times for the maximum strengthening effect
Lasts up to 33% longer than standard rotors to keep your vehicle on the road and off the lift
Power Slot Cryo Rotors boast exclusive Vac-U-Slot vents that keep your brakes cool under pressure and dry in the elements
Rotor hats, edges and vanes boast a protective black E-coating
Installing Power Slot Cryo Rotors takes 1-2 hours per axle or 2-4 hours for all four wheels
Your Power Slot Cryo Rotors are backed by a 3-month, 3,000-mile warranty
Description
When you're in between replacement rotors and a big brake kit for your high-horsepower ride, go with the smart compromise. Power Slot Cryo Rotors boast all the goodness of their top-quality slotted rotor siblings along with the unleashed power of cryogenics.
Why freeze rotors to a biting -300°F? By dropping Power Slot Cryo Rotors to such an unfathomable cold, their strength under tension and resistance to warping goes through the roof. It's a level of strength no other rotor can match.
The revolutionary design of Power Slot Cryo Rotors does wonders for the life of your brakes, too. Not only do their exclusive Vac-U-Slot vents keep things cool, they extend pad life and wick water away in wet weather, too. The result: unlimited stopping power for your high-horsepower ride or commercial rig.
*HP Plus ('N' Compound Code)*
HP Plus utilizes a unique Ferro-Carbon, high-tech friction material that was developed and manufactured for sport driving in autocross, Solo II and �track day� applications. The Ferro-Carbon formulation offers lower wear rates and higher torque values than other competitive materials.
Extremely high coefficient of friction makes HP Plus the perfect upgrade over stock for high performance streetcars used in autocross competition or that experience repetitive, heavy braking.
* Extremely High Friction Output
* Fade Resistant
* Worthy for Autocross & Club Racing Events
SET INCLUDES (4) Rotors
Set Front & Rear HP Plus Pads
http://www.xplosiveperformance.com/1...ds_p_2901.html
$762.14
plus shipping
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
