Closed Thread
Old 01-31-2012, 02:30 PM
hotrodstingray hotrodstingray is offline
Default LS7 427 Z06 crate motor
Up for sale is a new LS7 still mounted in the crate, bought this motor new a the dealership for my 1967 Corvette, now going with another route. I'm selling the motor $11,500 firm..located in San Francisco California.
This small-block V-8 dreams big, displacing big-block cubic inches at 7.0 Liters (427 cubic inches) and big-block power at 500 hp at 6200 rpm. It also benches 475 lb.-ft. of torque at 4800 rpm. Helping to create its high power and high revving capability are details such as cylinder heads with computer numerical control (CNC) intake and exhaust ports and combustion chambers - which creates ports with surgical accuracy for maximum power production. In addition, the intake valves and connecting rods are made out of high-strength lightweight titanium.
Motor Sold
Old 01-31-2012, 07:35 PM
g356gear's Avatar
g356gear g356gear is offline
Any accessories, etc?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 01-31-2012, 10:20 PM
Default Ls7
LS7 crate engine (P/N 17802397) includes:
Intake manifold with injectors
Injector wiring harness
Fuel rails
Throttle body
Dry sump oil pan
Exhaust manifolds
Flywheel & clutch
Harmonic dampener
Water pump and pulley
Coil Packs, spark plugs and wires
Engine sensors
LS7 crate engine does not include:
Dry sump oil lines
Dry sump tank
Engine beauty cover
Engine processor
Air filter/air box
Accessories or accessory drive
Engine control harness
Engine control module (ECU)
Old 02-01-2012, 04:50 PM
morris69 morris69 is offline
I'm interested in the motor. I live in sf. Call me 415. 720 3004
Old 05-29-2012, 11:08 AM
Default Ls7
No extra parts except for a pair of red LS7 Corvette covers
Old 06-23-2012, 08:22 AM
Default still available
If its still available i have 8500 cash. Call me if it sounds good
Closed Thread
