Old 02-19-2006, 05:18 PM
Derek69SS's Avatar
Default Best source for Rhino-Liner (or similar product)
I'm planning to spray my floorpans sometime in the next 2 weeks, but of course, I need to buy the products and the gun to spray it.
I'm looking for good quality, affordable price, and easy to use.
Old 02-19-2006, 05:45 PM
almcbri's Avatar
almcbri almcbri is offline
Derek,
check out "lizard skin" I heard of a couple guys using this and have been happy.
O'reillys carries a texture gun that will work I am sure. I even think wal-mart has one.
Andrew
http://www.hotrodscustomstuff.com/PS-LizSkin.html
Old 02-19-2006, 05:58 PM
Derek69SS's Avatar
Will that stuff work on the bottom side? They only show it in use on the top side of the floor pans. I'll probably do the top side later, but for now, I just want to coat the bottom with something that will seal everything up, and be very durable.
Old 02-19-2006, 06:08 PM
almcbri's Avatar
they recommend using it on both sides.
Old 02-19-2006, 10:46 PM
check your favorite local paint store... they should have some sort of spray in bedliner product in a kit form, spray gun/coating/catalyst for around a $100-150.
Old 02-20-2006, 07:49 AM
Derek,
We use this product from 3M - 3M
We get this from our local paint store I beleive it's $6 per can. It covers very well and a can goes a long way. I would say you could do the whole inside, underneath with 6 cans.
Jeff Allen
J2 Speed and Custom
Old 02-20-2006, 08:22 AM
Derek69SS's Avatar
OK, my next question is what I should do about the rust on the floor-pans and braces. This is a rust-belt car, so everything has a crusty layer of corrosion on it, but this isn't a show-car, and never will be. I have no intention of replacing floor-pans or sandblasting anything. I'm just going to scrape off all the loose-stuff and wire-brush it.
Should I POR-15 the whole thing, then coat it?
