Old 02-02-2012, 02:36 PM
sunoco67 sunoco67 is offline
Default What are you wetsanding clearcoat with?
What procedures are you guys using to finish sand the clearcoats. I have heard some guys are using a applying 2 coats of hi solids clear to the topcoat, wet sanding with 1000 grit paper reclearing 2 more coats and then wet sanding 1500,2000,3000 for a super flat no orange peel finish.
Thanks in advance
Old 02-02-2012, 04:04 PM
BODYSHOPMARO's Avatar
BODYSHOPMARO BODYSHOPMARO is offline
you hit it right on the money that will give you nice results i usually do three coats then hit it with a thousand than two to three more
Its only money/ 68 camaro/ Rich Sliwinske(PRECISION ENGINE AND MACHINE) 447 ci ERL sleeved/ landspeed development ported heads L92s/speedtech subframe/DSE mini tubbs/
Old 02-02-2012, 05:19 PM
NovaBlue71's Avatar
NovaBlue71 NovaBlue71 is offline
Default sanding clearcoat
I would recomend you shoot aleast 3 coats. You will get the car much straighter and flat if you sand with aleast 600 wet. I know of plenty of guys using spi clear that are doing 3 coats and 400 dry and 3 more. If you have any questions feel free to pm me . Joe
Old 02-02-2012, 05:24 PM
Ralphlovs72chev's Avatar
Ralphlovs72chev Ralphlovs72chev is offline
How long must you wait before hitting it with sand paper?
Old 02-02-2012, 05:46 PM
73CPCAMARO's Avatar
73CPCAMARO 73CPCAMARO is offline
We cut all of our jobs with 1200 - 1500 to start and then go to 2000 and finish in 3000. We do all of this dry. With our paint and booths, we can start within an hour of completion of the bake cycle.
This should be in the paint / body section.
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
