Old 02-03-2012, 12:22 PM
Xplosive Performance's Avatar
Xplosive Performance Xplosive Performance is offline
Default 63-82 Tubular A-Arms W/Coilovers 550# Springs- Car Set
  • 4 Light Weight Tubular A-Arms
  • 2 QA1 Coilovers Shocks
  • 2 Upper Shock Mounting Brackets
  • Spanner Wrenches
  • Complete With Ball Joints
Uppers
• 6 Degrees Positive Caster for Improved Highway Stability
• Light Weight, Super Strong Chromoly Steel Construction
• Delrin Bushings
• Gloss Black, Long Lasting Powder Coat Finish
• Pre-Assembled
• Van Steel Limited Life Time Warranty
Lowers
• Light Weight, Super Strong Tubular Chromoly Steel Construction
• Designed For the Semi-Coil Over Spring Conversion
• Delrin Bushings
• Pre-Assembled
Van Steel, an industry leader in Corvette Suspension and Brakes, has ready for delivery, light weight, front upper control arms for the 1963-82 Corvette. Realizing most Corvettes drive on radial tires, Van Steel has designed this arm with 6 degrees of positive caster for premium highway stability.
http://www.xplosiveperformance.com/6...t-_p_1810.html
$2100.00
Bob Brown
XP Motorsports LLC.
Xplosive Performance Inc.
[email protected]
AIM: CH3NO2fun
