Old 02-03-2012, 03:06 PM
kleners kleners is offline
Default Im stuck on what size to get.
Ok I am about to order the tires!!!
Im lost on which to get.
I have a 69 ss chevelle that is stripped and awaiting tires and rims to start back halfing the car.
I am going with COY's 20x14 that will be custom powder gunmetal center polished lip.
As for tires im looking at the Mickey Thompson sportsman S/R
But lost on two sizes
29X15.00R20LT this from what pics i can find looks alittle small (rubberband).
and 31x16.00R20LT Which looks the size i want.
But from the drawing mockup i did the 31 looks HUGE!! and the 29 looks perfect?
I am going Modern Prostreet the rear will no be lowered and will sit an inch about rim. anyone have any ideas on one or the other for my 69 chevelle?
Old 02-03-2012, 03:19 PM
JKnight JKnight is offline
I would inquire about the position of the valve stem on your Coy's wheels. I seem to remember someone saying they moved where they put them but on the set I have they put the valve stem directly in line with the brake caliper. This little detail makes me hate these wheels.
Edit...sorry, I know you asked about tires, but wanted to share this nugget of info as it may save you some heartache.
Old 02-03-2012, 03:22 PM
Ok i will check it out.
Im going disk in the rear. but big brakes are not a passion to me. so if i have to run an 11" or 12" that is fine. but ill check with them when i order them.
Old 02-04-2012, 12:13 AM
Viperlover's Avatar
Viperlover Viperlover is offline
I'd go with the 29s
Old 02-04-2012, 10:11 AM
Apogee Apogee is offline
31's are huge...but why wouldn't you build your car such that you could run either those or the 29's? It's a quasi-prostreet build with huge diameter wheels, so the more sidewall you can fit the better from a 1/4-mile performance perspective. It's a back-half project, so you can fit whatever you want and set your ride height accordingly.
Can you post the layout drawings for reference?
www.kore3.com
