Closed Thread
Old 02-05-2012, 04:20 PM
Van B's Avatar
Van B Van B is offline
Default FS 1967 Camaro Pro Touring G Machine
Absolutely no expense has been spared in building this high quality Pro Touring car that features excellent acceleration, handling, stopping, refined road manners, and great looks to match. The end product is an outstanding street car that is also very capable on the track.
The car was originally equipped with a 6 cylinder and a Powerglide, so no rare muscle cars were harmed in this build.
The list below highlights the parts that have gone into the build.
Wegner Motorsports L92 (6.2L) balanced and blueprinted Wegner CNC cylinder heads 10.87:1 compression,
Comp Cams hydraulic roller cam (.585/.595 lift, 291/301 duration)
LS7 lifters, Comp Cams 3/8” Magnum pushrods
Precision Metalcraft fabricated aluminum intake, FAST 92mm TB, 42 lb injectors
Pantera EFI ECU882C ECM
Champ pans baffled 5 ½ quart road race oil pan
Stewart water pump
ATI Super Damper
Griffin aluminum radiator
Wegner billet CNC valve covers
Hooker Headers Ceramic coated
Custom fabricated Stainless 3” exhaust with Magnaflow mufflers
Wegner billet accessory drive system
599HP at 6800 rpm 505 lb/ft torque at 5600 rpm at flywheel
Ricks Stainless narrowed gas tank with Walbro 255 gph fuel pump
Optima Red Top battery mounted in trunk
Engine compartment wiring painstakingly routed to be as hidden as possible
Transmission
Tremec T56 6 speed built by Liberty’s Gears
Spec Stage 3 clutch and pressure plate
ATS transmission cross member
Pro 5.0 shifter, Twist Machine billet lever
Custom Strange Chrome-moly driveshaft
Aluminum 2 piece driveshaft loop
Ford 9 inch rear end with Strange center section and 4:10 gears
Front Suspension
DSE tubular A-arms upper and lower
DSE coil over conversion
Koni coil over shocks with Afco 550 lb springs
DSE 1 1/8” hollow anti roll bar
Baer 6S six piston brakes with 14” 2 piece rotors
Rear Suspension
DSE Minitubs
Ridetech 4 link rear suspension
QA1 coil over shocks with 275 lb springs
Fully welded sub frame connectors
PBR (Baer) with 13” 2 piece rotors
Wheels / Tires
Kinesis K18R three piece forged wheels (18x8 front, 18x11 rear)
Falken Azenis tires (245/40ZR18 front, 315/30ZR18 rear)
ARP long wheel studs
Interior
Recaro Pole Position seats
G Force 5 point cam lock harnesses
Autometer Sport Comp gauges
Vintage Air Gen II Compac A/C and heat
6 point roll cage
DSE select a speed wiper motor
Exterior
BASF Diamont Base/Clear -Victory Red
Glasstek Carbon Fiber 2” cowl induction hood
Ring Brothers Billet “airframe” hood hinges
Marquez billet taillights with American Autowire LEDs.
Twist Machine Aluminum rear spoiler
Stock Camaro spoiler also goes with car and is painted to match
Stainless fastener kit from Prodigy Customs used on assembly
Front bumper bracket slots in fenders were eliminated. Firewall smoothed. Emblems, drip rail trim, wheel opening moldings, rocker trim and antenna hole were all eliminated and holes welded up. Trunk floor and fuel tank were modified to move the filler behind the rear license plate (like a 69 Camaro).
Car was media blasted to bare metal in 2008 and was found to be extremely solid. Full quarter panels had been installed by prior owner and by all appearances were professionally installed. The front fenders each received small (4”x4”) patch panels in the rear corners. There was no other rust found on the car.
It was painted in winter 2008-2009 in BASF Victory Red base/clear with a satin black bumblebee stripe on the nose. Wing window frames were re chromed as well as the rear bumper. All rubber seals are new. Glass is in great shape as is all stainless window trim.
The car works great whether you are carving up the twisty bits or cruising down the interstate. The double overdrive T56 transmission helps it deliver 20+ mpg on the highway. So much has gone into this project that it would be impossible to list it all. Please email with any specific questions you may have.
Camaro Performers Magazine feature car October 2010 (please note: rear suspension, rear end and exhaust have been upgraded since the article was written)
http://www.camaroperformers.com/feat...o/viewall.html
I will consider any of the following plus cash as trades. C5 or C6 Z06, LS powered 4th gen F Body, 5th gen Camaro SS, 04-06 GTO, CTS-V, BMW M3, Porsche 911, 20-28 foot enclosed trailer, Duramax powered truck, late model Mustang Boss 302 or GT500, or anything else that is interesting. No boats, ATVs or sport bikes. I would consider an even trade for the right C6 ZR-1.
$69,000
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 02-05-2012, 05:10 PM
Flash68's Avatar
Flash68 Flash68 is offline
That is a well built car!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-05-2012, 05:18 PM
camcojb camcojb is offline
great car Jeff. Good luck with the sale.
Old 02-05-2012, 06:22 PM
coolwelder62's Avatar
Ditto, GLWS
Old 02-05-2012, 06:30 PM
Van B's Avatar
Thanks guys! The good news is I don't have to sell it, but I am feeling like it is time for something new. The next build will be a little more economical. No $2k intakes and the like. I just can't justify having this much money in a car.
Jeff
99 Miata LS6
Old 02-05-2012, 09:47 PM
Gatekeeper's Avatar
Gatekeeper Gatekeeper is offline
Jeff, that is one wicked ride, just sent the link to a friend.
Lewis
Gatekeeper
Old 02-06-2012, 10:21 AM
syborg tt's Avatar
I agree awesome car.
ps I also agree on the 2,000 intake been there done that. My next project is going to have a carb !!
marty-mj
Old 02-07-2012, 06:20 PM
Van B's Avatar
What is wrong with people? I got an offer today on the Camaro for $3,550. Thanks a lot reelsteelusa! Jackass.
Jeff
99 Miata LS6
Old 02-07-2012, 06:22 PM
tones2SS's Avatar
tones2SS tones2SS is offline
DO WANT. That car is awesome.
GLWS
Old 02-07-2012, 06:28 PM
syborg tt's Avatar
okay serious that had to make you laugh. Some people just don't get it and never will.
marty-mj
Closed Thread
