Old 02-06-2012, 03:07 PM
SicMonte's Avatar
SicMonte SicMonte is offline
Default Oil filter comparison video
I have looked online but could not find any info or comparisons of the Fram HP series oil filters vs anything else. I had a couple laying around and decided to do one myself.
Old 02-06-2012, 06:27 PM
What about micron rating and flow rate? I like the metal end caps on the k&n.
Old 02-06-2012, 06:38 PM
Real men use real filters -- I run the PurePower cleanable billet versions in my cars... They actually FILTER the oil and have magnets in them.
Old 02-06-2012, 06:56 PM
p51mus p51mus is offline
Talking oil filter
You have way to much time on your hands!! Good job though.
gb69z
Old 02-06-2012, 07:06 PM
intocarss's Avatar
I've always ran a remote Oberg filter on the race car and now a K&N spin on
Here is an interesting site
http://minimopar.knizefamily.net/oilfilters/index.html
Old 02-06-2012, 08:07 PM
SicMonte's Avatar
Fram HP 4
http://www.summitracing.com/parts/FRM-HP4/
Fram HP 12
http://www.summitracing.com/parts/FRM-HP12/
K&N HP 3002 (equivalent to the Fram HP4)
http://www.summitracing.com/parts/KNN-HP-3002/
The only thing that worries me about the K&N's is the lack of an anti drain back valve...but does that matter if the filter is mounted vertical??
Old 02-06-2012, 08:20 PM
Couple things: The fram has a bypass valve rated at 22 psi. I prefer no bypass on a high dollar performance engine. A bypass is important on a daily driver. When you are pushing it, you want to filter ALL your oil.
The k&n does have a anti drain back valve, higher burst pressure, and lower micron rating.
Old 02-06-2012, 08:50 PM
SicMonte's Avatar
hp2002....no drain back valve
http://www.knfilters.com/search/prod...x?Prod=HP-2002
hp3002...has a drain back valve. hmmm
http://www.knfilters.com/search/prod...x?Prod=HP-3002
Old 02-06-2012, 08:53 PM
daddy warbucks
Old 02-06-2012, 09:05 PM
SicMonte's Avatar
I have been running the Fram HP12 for some time now with no problems. I mainly used it b/c of the added oil capacity.
I will most likely go with the K&N 3002 from now on.
