Old 02-06-2012, 10:40 PM
meanchicken meanchicken is offline
Default Offset on a 68 Camaro
Just bought some wheels to get my Camaro back on the road and realized too late that they have a +19mm offset....is this bad?
They are 17X8 with 5.25 BS also.
87 Grand National:Czarnota stroker roller V6;ported heads/intake;3200 billet stall 10";built 200R4;PTE 6265 DBB;3" THDP;TT Alky chip;60# inj;HD Adj WG actuator;AFPR;160* stat;Alkycontrol;TRC Big Mouth;PTE FMIC;Hooker cat back...and a boost gauge. 11.14@122 on 24lbs
4-sale 68 SS Camaro:ZZ502;TKO-600;Moser 12-bolt;Global West control arms;QA1 coil overs;SSBC power disks;quick ratio steering;Hotchkis sway bar;solid body mounts;Be Cool rad;Pertronix ign;other stuff. 4-sale
Old 02-07-2012, 12:05 PM
Swain's Avatar
Swain Swain is offline
They will work. Fronts may rub the chassis when you turn hard if the stock brakes, suspension are on still.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 02-07-2012, 12:19 PM
Apogee Apogee is offline
Offset and backspacing measure the same thing, just in from a different reference point. Offset is the distance from the mounting pad to the centerline of the wheel whereas backspacing is the measurement from the pad to the inner lip of the wheel.
You can always space a wheel out, not in.
Tobin
KORE3
www.kore3.com
Old 02-16-2012, 01:35 PM
Thanks.
I'm running Global West tubulars and SSBC brakes up front. Moser 12-bolt with SSBC's in the rear.
Tires arrived today....went with Kuhmo Ecsta SPT tires.
Old 02-17-2012, 07:58 AM
JustinB's Avatar
JustinB JustinB is offline
RSM? Not many 1st gens in RSM. Especially 1st gens with big blocks. Are you down off Melinda? I think we may have meet before. None the less, if you get any tire rub, let me know. I can get you some spacers to push the wheels out a tad, and I am in you area all the time.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
