Old 02-07-2012, 05:45 PM
richs71nova richs71nova is offline
Default Help!
Hey guys, i'm having a bit of a dilemma and didn't know if anyone else has run into a similar problem....
I bought the DSE solid, stock height body and radiator support mounts (part number 010301 for my 71 Nova. Right now my friend is trying to align all the body panels and it seems the radiator support mounts are too high... causing the front end panels not to line up square...
Has anyone had a similar problem???
Old 02-07-2012, 07:18 PM
DVS51 DVS51 is offline
The problem could be not having the factory spacers at the middle subframe mount (at the firewall). The Nova's have about a 3/8" steel spacer here that is not required on the Camaro. This would cause the subframe to run uphill and the radiator support to be too high.
