Old 02-14-2012, 01:20 PM
SuperB70's Avatar
SuperB70 SuperB70 is offline
Default Custom dimple dies + pictures
So as I promised to post this, here they are:
I'm proud to show my brain child:
Dimple Dies EVO II, 10 sizes, 1/2" to 3", integrated hole punch in every size, from Moc410M tool steel, heat treated to cutting tool specs
Rockwell scale: HRC56, should cut stainless like knife through butter.
I have to honest, I didnt make them, I desing them but my bubby did them with CNC-machine. I just deliveryd the steel rods for them.
Some are still burn oil dirty, some I just sand blasted cleaner.
Each size has normal dies has hole, a pillow (the ring) and a cutting die has M10 threats so can be work with strong bolt or HF manual hydralic hole punch set with new center bolt.
That I've already bought.
Normal dies hole is used as a guide to guide rod that is threadet on the cutting die, it is in other side of the pillow when hole is made at the straight edge on other side of the pillow. If working with shop press, just need to drill hole so the guide bolt get through to cutting material to guide dies together.
Anyone getting this?
I could polish them, now just clean them. They are tools not jewelry.
Made a test run with small ones to 2mm/just over 1/16" aluminium
So, what do you think? I'm not selling them, just showing..
, Juhani
Old 02-14-2012, 01:45 PM
wellis77's Avatar
wellis77 wellis77 is offline
Sweet!!!
Will Ellis
Project SCUD, 1969 Dodge Dart Swinger, 1/2 Dart / 1/2 Viper
Old 02-14-2012, 02:11 PM
It looks like a slick set up. Very Nice.
Old 02-14-2012, 02:13 PM
boonedog boonedog is offline
whos selling them for you?
Old 02-14-2012, 02:29 PM
SuperB70's Avatar
Thank guys..
No one. Sorry...
I had them made for me by my friend.
They are really one-offs...
, Juhani
Old 02-14-2012, 07:41 PM
Cread01 Cread01 is offline
very nice. I have been thinking about making a few different sizes for a couple of projects.
gonna have to start makin some chips.
Old 02-16-2012, 09:28 AM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
I sure would like to have some of those .....
Old 02-21-2012, 10:32 PM
David Pozzi's Avatar
If you are not going to use a hydraulic ram on them, then the larger ones need a larger threaded hole. I think they need to be either 5/8" or 3/4" or you won't be able to get enough torque to punch through. Otherwise, nice!
David
http://www.PozziRacing.com
Old 02-22-2012, 01:02 PM
SuperB70's Avatar
^ I know. That is only thing I would chance if I would do them again.
Would make threads to match hydralic punch rods.
Now they are so strong that cant make new threads.
I did use them on aluminium on fuel tank build. Made holes with shop press to baffles, they work'd great.
, Juhani
Old 02-23-2012, 06:29 PM
HIFLYR's Avatar
HIFLYR HIFLYR is offline
http://www.mygreenlee.com/GreenleeDo...adodb_next_pag
You can buy something close here from greenlee not sure how big they build the knockout dies but they have 4 pages of them.
