Old 02-15-2012, 04:17 PM
xtreme's Avatar
xtreme xtreme is offline
Default LS1-LS6 Engines Billet Aluminum Dry Sump Pans For Sale 850.00 each!
1 SOLD!!!!! ONLY TWO PANS LEFT!!!!!!!!!
LS1-LS6 Engines Billet Aluminum Dry Sump Pans For Sale! Here is your chance to own one very expensive and rare fully CNC billet aluminum dry sump pan at a great deal. From Dailey Engineering these pans retail for $1515.00 each without the pumps!
These are custom made by Dailey Engineering, Pricing them to move! Once there gone, there gone!
http://www.daileyengineering.com/ls_big_pump.htm
These pans are completely designed and CNC cut from solid chunks of billet aluminum. There are no hoses at all that connect the scavenges to the pumps, instead there are very intricately machined oil channels leading from each segmented section. They have super low profiles for amazing clearances, fully machined for o ring gaskets etc. There are no welds to crack, or chance of having contamination and they are very strong pieces. They are without a doubt the nicest custom designed car part I have ever seen and you can only imagine the amount of work put into designing these, from machining them, counter sinking screws, tapping threads, machining o ring grooves etc. etc.
These would be a great option for any racer, custom builder, etc. Keep in mind once you add up the cost of all the hoses, a custom pan, oil fittings, and not to mention the size and weight of all these items, you might wish you had one of the billet pans instead. Especially for low cars, drag cars, and clearances.
Both pans are used and have signs or wear, nothing that affects their pefromance. I have thoroughly cleaned each pan, but each screw will need to be loctited for future use. Additionally there were no o rings included on the tops of the pans, but you can very easily buy the correct o ring and splice it yourself.
When it comes to pumps, you could buy a pump for your application from Dailey or custom machine an adapter to your current pump that you have. One pan is square ports and one is circular.
One pan has the very front of the pan slightly machined, probably to fit a belt drive cover. I have included a picture of it, shouldnt be a problem for any application.
Please make sure they are intended for your particular application. These are really nice and once there gone, there gone! Buyer pays shipping and Handling in addition the selling price of $850.00 FIRM each.
$1515 New- $850 Used= Save $665
Message me if you would like one or email me [email protected] All sales final!
Old 02-21-2012, 02:36 PM
xtreme's Avatar
Update, one already sold, two left! Better Pics!
