Old 02-16-2012, 06:28 AM
Spitfire100 Spitfire100 is offline
Default CPP MCPV Master Cylinder ?
Trying to keep engine bay clean as possible the CPP MCPV master cylinder has all the components needed built in ie. proportioning valve etc. Does anyone have experience with this item positive or negative? It will be used on a 69 Camaro with after market disc brakes all corners. Any comments will be appreciated.
Old 02-17-2012, 03:47 PM
keithcollins keithcollins is offline
Default Master cly
I installed one a couple of months ago. I love the feel of the pedal the simplicity of the adjustments.
Old 02-17-2012, 04:44 PM
JustinB's Avatar
JustinB JustinB is offline
I have installed a few of the CPP masters without any issues. I still like a Wilwood master with an external prop but if you want it all contained in the same unit, its a good option.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 02-17-2012, 06:53 PM
Apogee Apogee is offline
I agree with Justin, not a bad unit if everything goes as planned and functions like it should. If/when they do go bad, they can be difficult to isolate and troubleshoot due to the integral nature of the prop valve and metering orifice.
Tobin
KORE3
www.kore3.com
