Old 02-18-2012, 10:38 AM
DETON8R's Avatar
DETON8R DETON8R is offline
Default Does Replacement 69 Camaro Billet RS Tail Light Need Light Housing??
I'm looking for an Billet RS tail light that does not need the tail light housings to mount the replacement lens assembly. Is there a billet replacement RS tail light set that doesn't need the bucket/housing?
I have none of the lights, hardware, wiring, nothing..... And if I'm spending over $300 for a billet tail light set, I don't want to drop more money for the housing and stud kit if I don't need to.
I'm going to go with a custom wiring harness, so I'm not worried about any old wiring connections to the light assembly. I don't think that housing is needed with LED's, as there is no need for the reflector in the housing. Also, I'm mocking up the roll cage bracing in rear of the car and I'd like to run the bracing close to the tail panel as possible so I can hide the bracing behind a speaker box enclosure.
I've checked most of the popular sites, Fesler, Billet Specialties, Marquez, etc. and no info about installation or parts needed from the stock configuration!! So............ I need some help.
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 02-18-2012, 05:54 PM
redfire69's Avatar
redfire69 redfire69 is offline
I think all the manufacturers you mentioned assume you'll use the stock buckets. I think you could fab up slimmer ones for LEDs.
Ron
69 Camaro Redfire
Old 02-18-2012, 06:35 PM
Musclerodz's Avatar
The housing is required because it holds the bezel in place and the leds. The billet units are designed to be installed just like the factory parts were that are being replaced.
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-19-2012, 10:54 PM
Camaro Dave's Camaro Dave's is offline
all of the 69 billet tails on the market require you to reuse the housing/bucket
if your interested ,we stock everything in house.... call me and I will make you a killer deal on rs billet tails with some used housings and hardware
Dave @
Camaro Dave's
303-332-6379
www.Camaro-Daves.com
Old 02-26-2012, 07:11 PM
DETON8R's Avatar
Default Thanks !!
Thanks Dave, PM sent.
