Old 02-21-2012, 10:34 AM
DBasher's Avatar
DBasher DBasher is offline
Default Keeping the heat out
Just wondering what's being used to keep engine/exhaust heat out of the cockpit. My engine is set back 4-5" and I'm concerned about cooking myself.
The trip to Bonneville last year in my brothers truck was unbearable. I'm trying to avoid driving around in my underwear this summer.
Dan
Old 03-04-2012, 10:25 AM
EBMC's Avatar
EBMC EBMC is offline
Try this: http://www.heatshieldproducts.com/pr...ield-mat/79/21
Steve Keefer
Old 03-04-2012, 10:37 AM
FETorino's Avatar
FETorino FETorino is offline
Default Interesting
Originally Posted by EBMC View Post
Do you use it on the inside of the tunnel under the car (seems that way from the description) or on the floorboards under sound deadening?
Rob in SoCal
Old 03-05-2012, 07:29 AM
EBMC's Avatar
I suppose it could be used both ways. We've used it in small sections applied to exhaust heat shields we've made. Seemed to hold up well.
Steve Keefer
Old 03-22-2012, 09:21 PM
Classic442's Avatar
Classic442 Classic442 is offline
I used Second Skin products. I have installed damplifier, Heatwave Pro (HP), and some UltraTouch heat insulator.
Take a look at this item available online only; from Home Depot.
UltraTouch 48 in. x 6 ft. Radiant Barrier ($18.96).
I ordered it and it arrived in 4 days, and you can't argue about the price.
After gathering these items up I test fit my Dual Gate shifter and console and trimmed the carpet and HP to fit around or under it. I then went looking for some closed cell foam locally and found a vendor. Before going to their shop I stopped in at a local U-Pull it to get a few parts and see if I could scavenge some padding from a few late model wrecks. The first car I walked by was a 93 Lincoln Towncar. The rear seat was removed and I found that they have a 1/4 CCF padding under the entire rear seat all the way to the rear deck. It is bonded to a layer of mass load vinyl and I was able to pull the CCF/MLV pads from 4 other similar cars. I also had a wheel barrel full of other types of padding and trunk type carpet. Total cost out the door was under $21.00.
If your looking for a CCF MLV product check out the late model Lincolns at your local yard.
Back from the Paint Shop with SC&C Stage II suspension, and 13 Baer brakes.
http://thumb3.webshots.net/t/87/87/7...3GQjnZw_th.jpg
